midimasterclock [2011/07/11 08:47] bajrangkhichi96 |
midimasterclock [2016/06/25 18:16] psykhaze [Further Informations] |
Line 7: | Line 7: | ||
===== TOP - backview ===== | ===== TOP - backview ===== | ||
- | You can see 6 Channels [A-F]. Every Channel is made up of one MIDI-Out and a footpedal-in. Moreover you can find a MIDI-in and a [[http://www.mycaal.com/|loan modification]] Display out-jack. | + | You can see 6 Channels [A-F]. Every Channel is made up of one MIDI-Out and a footpedal-in. Moreover you can find a MIDI-in and a Display out-jack. |
Line 40: | Line 40: | ||
{{:normaluhr_back.jpg?530}} | {{:normaluhr_back.jpg?530}} | ||
- | [http://www.monarch-garments.com/cat_breeches.asp breeches] | ||
- | [http://www.vasundharafertility.com/infertility.php infertility] | ||
===== Further Informations ===== | ===== Further Informations ===== | ||
See the forum: | See the forum: | ||
- | * [[http://www.midibox.org/forum/index.php?topic=7306.0|Midi-Master-Clock (german)]] | + | * [[http://midibox.org/forums/topic/11413-midi-master-clock|Midi-Master-Clock]] |
- | * [[http://www.midibox.org/forum/index.php?topic=5691.0|clockBox v 1.0]] – This application sends a MIDI clock and outputs a 24ppqn signal at CORE::J14 from 48 to 255 BPM | + | |
* [[http://www.ucapps.de/mios/clockbox_multi.pdf]] - Connection diagram for this project including multiple MIDI outputs. | * [[http://www.ucapps.de/mios/clockbox_multi.pdf]] - Connection diagram for this project including multiple MIDI outputs. | ||
- | * [[http://www.diamondlinks.net/|Link Building]] | ||
- | * [[http://cvresumewritingservices.org/|Resume]] | ||
- | * [[http://www.choithraminternational.com ib program]] |
