midimasterclock [2011/07/14 06:09] miller88 |
midimasterclock [2011/08/08 08:22] nancewleach |
Line 7: | Line 7: | ||
===== TOP - backview ===== | ===== TOP - backview ===== | ||
- | You can see 6 Channels [A-F]. Every Channel is made up of one MIDI-Out and a footpedal-in. Moreover you can find a MIDI-in and a [[http://www.mycaal.com/|loan modification]] Display out-jack. | + | You can see 6 Channels [A-F]. Every Channel is made up of one MIDI-Out and a footpedal-in. Moreover you can find a MIDI-in and a Display out-jack. |
Line 17: | Line 17: | ||
* By pushing "Play" while playing the channel will break and by pushing "Play" again it will start when the sequenz is again on the position it braeked. | * By pushing "Play" while playing the channel will break and by pushing "Play" again it will start when the sequenz is again on the position it braeked. | ||
- | On the right there is a advanced Pitch-section. A Pitch-Fader for the global tempo of the Midi-Cl. Among this fader there is a joystick to pitch the tempo [[http://www.truckaccidentlawyersource.com/| truck accident lawyer]]temporary - like pushing or pulling the Vinyl. The more you push the joystick in one direction the more the tempo pitchs temporary up/down. | + | On the right there is a advanced Pitch-section. A Pitch-Fader for the global tempo of the Midi-Cl. Among this fader there is a joystick to pitch the tempo temporary - like pushing or pulling the Vinyl. The more you push the joystick in one direction the more the tempo pitchs temporary up/down. |
And among this Joystick the to button got the same function: pushing "+" means speed up and "-" slow down (both temporary) | And among this Joystick the to button got the same function: pushing "+" means speed up and "-" slow down (both temporary) | ||
Line 40: | Line 40: | ||
{{:normaluhr_back.jpg?530}} | {{:normaluhr_back.jpg?530}} | ||
- | [http://www.monarch-garments.com/cat_breeches.asp breeches] | ||
- | [http://www.vasundharafertility.com/infertility.php infertility] | ||
- | *[http://www.choithraminternational.com schools indore] | ||
===== Further Informations ===== | ===== Further Informations ===== | ||
Line 49: | Line 46: | ||
* [[http://www.midibox.org/forum/index.php?topic=5691.0|clockBox v 1.0]] – This application sends a MIDI clock and outputs a 24ppqn signal at CORE::J14 from 48 to 255 BPM | * [[http://www.midibox.org/forum/index.php?topic=5691.0|clockBox v 1.0]] – This application sends a MIDI clock and outputs a 24ppqn signal at CORE::J14 from 48 to 255 BPM | ||
* [[http://www.ucapps.de/mios/clockbox_multi.pdf]] - Connection diagram for this project including multiple MIDI outputs. | * [[http://www.ucapps.de/mios/clockbox_multi.pdf]] - Connection diagram for this project including multiple MIDI outputs. | ||
+ | [[http://customcollegeessays.com/index.php|college essay]] | ||
