midimasterclock [2011/07/26 01:15] belindabride Minor edits |
midimasterclock [2016/06/25 18:16] psykhaze [Further Informations] |
Line 3: | Line 3: | ||
{{midimasterclock:1.jpg?450}} | {{midimasterclock:1.jpg?450}} | ||
- | On the top of the picture you can find the backview (jackview). In the middle the [[http://www.brettmerl.biz/|Brett Merl]] frontpanel and on the bottom the peripherie. | + | On the top of the picture you can find the backview (jackview). In the middle the frontpanel and on the bottom the peripherie. |
===== TOP - backview ===== | ===== TOP - backview ===== | ||
- | You can see 6 Channels [A-F]. Every Channel is made up of one MIDI-Out and a footpedal-in. Moreover you can find a MIDI-in and a [[http://www.mycaal.com/|loan modification]] Display out-jack. | + | You can see 6 Channels [A-F]. Every Channel is made up of one MIDI-Out and a footpedal-in. Moreover you can find a MIDI-in and a Display out-jack. |
Line 17: | Line 17: | ||
* By pushing "Play" while playing the channel will break and by pushing "Play" again it will start when the sequenz is again on the position it braeked. | * By pushing "Play" while playing the channel will break and by pushing "Play" again it will start when the sequenz is again on the position it braeked. | ||
- | On the right there is a advanced Pitch-section. A Pitch-Fader for the global tempo of the Midi-Cl. Among this fader there is a joystick to pitch the tempo [[http://www.truckaccidentlawyersource.com/| truck accident lawyer]]temporary - like pushing or pulling the Vinyl. The more you push the joystick in one direction the more the tempo pitchs temporary up/down. | + | On the right there is a advanced Pitch-section. A Pitch-Fader for the global tempo of the Midi-Cl. Among this fader there is a joystick to pitch the tempo temporary - like pushing or pulling the Vinyl. The more you push the joystick in one direction the more the tempo pitchs temporary up/down. |
And among this Joystick the to button got the same function: pushing "+" means speed up and "-" slow down (both temporary) | And among this Joystick the to button got the same function: pushing "+" means speed up and "-" slow down (both temporary) | ||
Line 26: | Line 26: | ||
===== BOTTOM - peripherie ===== | ===== BOTTOM - peripherie ===== | ||
Here is an external 3x7-Seg Display to show the position. (While playing live in a team: "OK - break on the 32^th bar!" | Here is an external 3x7-Seg Display to show the position. (While playing live in a team: "OK - break on the 32^th bar!" | ||
- | Every channel-footswitch can by route by the menu to the "Stop" or "Play" - button. Even can [[http://www.diamondlinks.net|link building service]] think about Master-footswitch. | + | Every channel-footswitch can by route by the menu to the "Stop" or "Play" - button. Even can think about Master-footswitch. |
Line 40: | Line 40: | ||
{{:normaluhr_back.jpg?530}} | {{:normaluhr_back.jpg?530}} | ||
- | [http://www.monarch-garments.com/cat_breeches.asp breeches] | ||
- | [http://www.vasundharafertility.com/infertility.php infertility] | ||
- | *[http://www.choithraminternational.com schools indore] | ||
===== Further Informations ===== | ===== Further Informations ===== | ||
See the forum: | See the forum: | ||
- | * [[http://www.midibox.org/forum/index.php?topic=7306.0|Midi-Master-Clock (german)]] | + | * [[http://midibox.org/forums/topic/11413-midi-master-clock|Midi-Master-Clock]] |
- | * [[http://www.midibox.org/forum/index.php?topic=5691.0|clockBox v 1.0]] – This application sends a MIDI clock and outputs a 24ppqn signal at CORE::J14 from 48 to 255 BPM | + | |
* [[http://www.ucapps.de/mios/clockbox_multi.pdf]] - Connection diagram for this project including multiple MIDI outputs. | * [[http://www.ucapps.de/mios/clockbox_multi.pdf]] - Connection diagram for this project including multiple MIDI outputs. | ||
