On the top of the picture you can find the backview (jackview). In the middle the frontpanel and on the bottom the peripherie.
You can see 6 Channels [A-F]. Every Channel is made up of one MIDI-Out and a footpedal-in. Moreover you can find a MIDI-in and a loan modification Display out-jack.
A Display and Inc-Dec-knob for the typical menu-edit. Push on Inc/Dec means “Yes” the button left is “No”. Under the disply there are four LEDs to show the step. 12 Buttons, two for each channel.
On the right there is a advanced Pitch-section. A Pitch-Fader for the global tempo of the Midi-Cl. Among this fader there is a joystick to pitch the tempo temporary - like pushing or pulling the Vinyl. The more you push the joystick in one direction the more the tempo pitchs temporary up/down. And among this Joystick the to button got the same function: pushing “+” means speed up and “-” slow down (both temporary)
The three buttons on the right are all to manipulate the mastertempo. “Play” means start. Pushing again: break and by pushing a third time the Masterclock continues at the same position it stopped. By pushing “Stop” it stops, and punching “Play” after “stop” will start at the beginning.
The “TAP”-Button is to tap the tempo as usual.
Here is an external 3×7-Seg Display to show the position. (While playing live in a team: “OK - break on the 32^th bar!” Every channel-footswitch can by route by the menu to the “Stop” or “Play” - button. Even can think about Master-footswitch.
[http://www.monarch-garments.com/cat_breeches.asp breeches] [http://www.vasundharafertility.com/infertility.php infertility]
See the forum:
