msq-cc-lre [2018/05/11 18:14] phatline [Introduction] |
msq-cc-lre [2022/02/24 21:26] phatline [MSQ-CC-LRE] |
Line 3: | Line 3: | ||
Synth-Patch-Editor & Motion-Sequencer 4 ControlChange (= CC-Automation)\\ | Synth-Patch-Editor & Motion-Sequencer 4 ControlChange (= CC-Automation)\\ | ||
{{:phatline:MSQ_CC_LRE_Thumbnail.jpg?600|}}\\ | {{:phatline:MSQ_CC_LRE_Thumbnail.jpg?600|}}\\ | ||
- | {{youtube>A_17FqmB53Y}}\\ | + | {{youtube>https://youtu.be/43pH21KppLc}}\\ |
Line 36: | Line 36: | ||
* [[home:mbhp:module:core32]]\\ | * [[home:mbhp:module:core32]]\\ | ||
* [[http://ucapps.de/mbhp_midi_io.html|1xMidi IO]] connect 1 midicontroller and 1 Note/Clock-Source/Destination\\ | * [[http://ucapps.de/mbhp_midi_io.html|1xMidi IO]] connect 1 midicontroller and 1 Note/Clock-Source/Destination\\ | ||
- | * SD-Card, formated with FAT32, and the file "bcr1.syx" on it\\ | + | * SD-Card, formated with FAT32\\ |
* Soldering Iron, Wires, PCB....\\ | * Soldering Iron, Wires, PCB....\\ | ||
- | * USB Power Supply... I tried to use the Midi-BUS-Power from BCR2000 but it is too weak! | + | * USB Power Supply\\ |
* 2x LRE 8x2 [[mb-lre8x2cs_pcb]] | * 2x LRE 8x2 [[mb-lre8x2cs_pcb]] | ||
* 3 extra Encoders and Ledrings (to controll the unit) + Pushfunction inclusive Button LED | * 3 extra Encoders and Ledrings (to controll the unit) + Pushfunction inclusive Button LED | ||
Line 45: | Line 45: | ||
* 1x DINX4 | * 1x DINX4 | ||
* 1x DOUTX4 | * 1x DOUTX4 | ||
==== Setting ==== | ==== Setting ==== | ||
Line 63: | Line 62: | ||
===== Firmware ===== | ===== Firmware ===== | ||
- | V0. from 9.04.2018{{:phatline:MSQ_CC_LRE_V0.NordDrum2.zip|}} \\ | + | V1. from 9.05.2018{{:phatline:MSQ_CC_LRE_V0.NordDrum2.zip|}} \\ |
- | hardcodet for a NordDrum2 \\ | + | hardcodet for a NordDrum2 - but change-able in Mapping via a Array in Sourceode: \\ |
+ | this is the maping which says wich of the 32 internal CCs are one of the outhernal CCs (0-127):\\ | ||
+ | {{:phatline:MSQ_LRE_cc-maping-deep-edit.png?700|}}\\ | ||
+ | This Mapping says which one of the 32 internal CCs are positioniered in the Mixer/Overview/Channelstrip-Mode\\ | ||
+ | {{:phatline:.MSQ_LRE_cc-maping-overview-map.png?700|}}\\ | ||
+ | there are 8 deep edit pages, and 8 overview pages.\\ | ||
===== CC Routing to Synths ===== | ===== CC Routing to Synths ===== | ||
MSQ_CC_LRE internal i have 8x32 CCs, they are always identical. \\ | MSQ_CC_LRE internal i have 8x32 CCs, they are always identical. \\ |
