msq-cc-lre [2018/05/11 18:23] phatline |
msq-cc-lre [2018/10/10 00:54] phatline [Hardware Requirements] |
Line 36: | Line 36: | ||
* [[home:mbhp:module:core32]]\\ | * [[home:mbhp:module:core32]]\\ | ||
* [[http://ucapps.de/mbhp_midi_io.html|1xMidi IO]] connect 1 midicontroller and 1 Note/Clock-Source/Destination\\ | * [[http://ucapps.de/mbhp_midi_io.html|1xMidi IO]] connect 1 midicontroller and 1 Note/Clock-Source/Destination\\ | ||
- | * SD-Card, formated with FAT32, and the file "bcr1.syx" on it\\ | + | * SD-Card, formated with FAT32\\ |
* Soldering Iron, Wires, PCB....\\ | * Soldering Iron, Wires, PCB....\\ | ||
- | * USB Power Supply... I tried to use the Midi-BUS-Power from BCR2000 but it is too weak! | + | * USB Power Supply\\ |
* 2x LRE 8x2 [[mb-lre8x2cs_pcb]] | * 2x LRE 8x2 [[mb-lre8x2cs_pcb]] | ||
* 3 extra Encoders and Ledrings (to controll the unit) + Pushfunction inclusive Button LED | * 3 extra Encoders and Ledrings (to controll the unit) + Pushfunction inclusive Button LED | ||
Line 45: | Line 45: | ||
* 1x DINX4 | * 1x DINX4 | ||
* 1x DOUTX4 | * 1x DOUTX4 | ||
==== Setting ==== | ==== Setting ==== |
