opl3_module_modified [2014/01/28 10:26] eptheca |
opl3_module_modified [2014/01/28 11:05] eptheca |
Line 1: | Line 1: | ||
====== MBHP_OPL3 module modifications, the 5V option ====== | ====== MBHP_OPL3 module modifications, the 5V option ====== | ||
- | The OPL3 module originally has three TL074 op-amps, and a circuit that needs +/-12V bipolar power supply. | + | The [[http://www.ucapps.de/mbhp_opl3.html|MBHP_OPL3]] module originally has three TL074 op-amps, and a circuit that needs +/-12V bipolar power supply. |
- | In Wilba and nILS sammichFM, they use two OPA4348 rail-to-rail op-amps, that can be powered by 5V. | + | In Wilba and nILS [[sammichfm|sammichFM]], they use two OPA4348 rail-to-rail op-amps, that can be powered by 5V. |
- | Sauraen suggested another 5V rail-to rail op-amp, the MCP6004, which is pin compatible with the TL074, and a way to modify the OPL3 module to use these. | + | Sauraen suggested another 5V rail-to rail op-amp, the MCP6004, which is pin compatible with the TL074, and a way to modify the OPL3 module to use these.[[http://midibox.org/forums/topic/18492-mbfm-5v-option/]] |
- Replace R5,R7,R10 and R13 with jumpers\\ | - Replace R5,R7,R10 and R13 with jumpers\\ | ||
Line 27: | Line 27: | ||
- Connect the right pad of this bridge to the 5V pin in the middle of the board with a jumper\\ | - Connect the right pad of this bridge to the 5V pin in the middle of the board with a jumper\\ | ||
- Connect the left pad of this bridge to the 5V pin of the Oscillator with a jumper\\ | - Connect the left pad of this bridge to the 5V pin of the Oscillator with a jumper\\ | ||
+ | - Two separate 5V voltage regulators, IN pins connected through a ferrite bead\\ | ||
+ | - One 5V source to Core and J1 of OPL3 module\\ | ||
+ | - The other 5V source to J3 of OPL3 module\\ | ||
+ | - Ground ONLY to J3!\\ | ||
+ | Tips:\\ | ||
+ | - Starlike wiring (Ground from PSU to each module + Audio outputs)\\ | ||
I can vouch for these mods :)\\ | I can vouch for these mods :)\\ | ||
- | My MIDIboxFM has hardly any noise, and it has enough gain. | + | My MIDIbox FM V1 has hardly any noise, and it has enough gain. |
{{:opl3.jpg?direct|}} | {{:opl3.jpg?direct|}} | ||
Line 36: | Line 45: | ||
