Both sides previous revision Previous revision | Next revision Both sides next revision | ||
opl3_module_modified [2014/01/28 11:04] eptheca |
Line 1: | Line 1: | ||
====== MBHP_OPL3 module modifications, the 5V option ====== | ====== MBHP_OPL3 module modifications, the 5V option ====== | ||
- | The [[http://www.ucapps.de/mbhp_opl3.html|OPL3]] module originally has three TL074 op-amps, and a circuit that needs +/-12V bipolar power supply. | + | The [[http://www.ucapps.de/mbhp_opl3.html|MBHP_OPL3]] module originally has three TL074 op-amps, and a circuit that needs +/-12V bipolar power supply. |
In Wilba and nILS sammichFM, they use two OPA4348 rail-to-rail op-amps, that can be powered by 5V. | In Wilba and nILS sammichFM, they use two OPA4348 rail-to-rail op-amps, that can be powered by 5V. |
