pedal_box [2010/04/13 07:42] durisian |
pedal_box [2014/01/19 10:08] shuriken |
Line 54: | Line 54: | ||
* **Expression Pedals** | * **Expression Pedals** | ||
* Up to 8 Expression Pedals or Pedal inputs (CV / 10k pot) | * Up to 8 Expression Pedals or Pedal inputs (CV / 10k pot) | ||
- | * Individual option for pedals to follow program change messages changing the midi messages sent | + | * Individual option for pedals to be 'dynamic' by changing the midi messages sent based on the Rig COntrol Patch Change |
* Value scaled between pre-defined min and max values (can also be different for each program change) | * Value scaled between pre-defined min and max values (can also be different for each program change) | ||
+ | * A MIDI CC can be configured to act exactly as if it were connected to an analogue in (The 8 limit still applies) | ||
* **LCD Display** | * **LCD Display** | ||
* Named Program Changes | * Named Program Changes | ||
Line 81: | Line 82: | ||
* Up to 128 patches can be listed in any order | * Up to 128 patches can be listed in any order | ||
* Cue Next / Cue Previous can be done from any button or a MIDI IN event | * Cue Next / Cue Previous can be done from any button or a MIDI IN event | ||
+ | * **PedalSwap** | ||
+ | * Allows dynamic pedals to change there midi settings without utilizing Rig Control | ||
* PC Editor files allows easy...ish customization for different MIDI devices. | * PC Editor files allows easy...ish customization for different MIDI devices. | ||
* Settings configurable from box. (this is a very slow process but can you help you out in pinch, it's far quicker to use the PC Editor). \\ | * Settings configurable from box. (this is a very slow process but can you help you out in pinch, it's far quicker to use the PC Editor). \\ | ||
Line 163: | Line 166: | ||
</box> | </box> | ||
Line 169: | Line 190: | ||
======Manual====== | ======Manual====== | ||
- | Pedal Box / Pedal Board [[pedal_box:manual]] | + | [[http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fpedalbox_v2%2Fdocs%2FPB_Manual.pdf|The Complete Usage Manual]] |
- | PC Editor Manual [[pedal_box:pc_editor_manual|manual]] | + | Help can be found in the [[http://midibox.org/forums/topic/9081-the-pedal-box-and-pedal-board-thread | Pedal Box forum thread ]] |
- | Help can be found in the [[http://www.midibox.org/forum/index.php/topic,9770.30.html | Pedal Box forum thread ]] | + | \\ |
Line 390: | Line 412: | ||
<box 46% left round bluedark|Device Bankstick Downloads> | <box 46% left round bluedark|Device Bankstick Downloads> | ||
- | [[http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fpedalbox_v2%2FDevice_Config_Files%2FV-Amp%2FV-Amp.zip|Behringer V-Amp Series]] | + | {{:mcrozier:v-amp.zip|Behringer V-Amp Series}} |
</box> \\ | </box> \\ | ||
<box 46% left round|PC Editor> | <box 46% left round|PC Editor> | ||
- | [[http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fpedalbox_v2%2Feditor%2Fv2%2FPBEditor2.zip|Pedal Board Editor 2 v1.0]] | + | {{:mcrozier:pbeditor2.zip|Pedal Board Editor 2 v1.0}} \\ |
+ | Please note the editor requires a minimum of WinXP with .Net 3.5 \\ | ||
- | + | <box 98% round|Docs> | |
- | [[http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fpedalbox_v2%2Fdocs%2FPB_Manual.pdf|The Complete Usage Manual]] | + | {{:mcrozier:pb_manual.pdf|The Complete Usage Manual}}</box> |
Line 428: | Line 451: | ||
- | Please report bugs in the [[http://www.midibox.org/forum/index.php/topic,9770.30.html | Pedal Box forum thread ]] | + | Please report bugs in the [[http://midibox.org/forums/topic/9081-the-pedal-box-and-pedal-board-thread | Pedal Box forum thread ]] |
Line 587: | Line 610: | ||
The shift register of the 1st digit (the one's display) must be defined in pbx_config.h \\ | The shift register of the 1st digit (the one's display) must be defined in pbx_config.h \\ | ||
The second digit (ten's) will be automatically assigned to the next shift register. | The second digit (ten's) will be automatically assigned to the next shift register. | ||
+ | If only 1 digit is used, and bank goes higher than 9. The dot will light up to let you know that '0' is actually 10, '1' is actually 11, etc \\ | ||
In place of LED digits. A 2x20 LCD Display can be used (instead of 2x16). The last 4 charcters of each line are used for bank display. This will only happen when DIGITS_CONNECTED = 0 in pbx_config.h. | In place of LED digits. A 2x20 LCD Display can be used (instead of 2x16). The last 4 charcters of each line are used for bank display. This will only happen when DIGITS_CONNECTED = 0 in pbx_config.h. | ||
Line 615: | Line 640: | ||
==== Connection Overview ==== | ==== Connection Overview ==== | ||
{{http://www.durisian.com/midibox/PB/images/pbd_din_dout_connections.jpg}} | {{http://www.durisian.com/midibox/PB/images/pbd_din_dout_connections.jpg}} | ||
+ | **Please Note:** Default connections have changed since 2.6. The default has only one digit connected to SR 5. With bank and PedalSwap footswitches and LED's attched to SR 4 | ||
Pedal Board Test Bench \\ | Pedal Board Test Bench \\ | ||
Line 658: | Line 686: | ||
{{mcrozier:pedal_board_max.jpg}} \\ | {{mcrozier:pedal_board_max.jpg}} \\ | ||
You know you want to build it! | You know you want to build it! | ||
