pedal_box [2010/04/13 08:31] durisian |
pedal_box [2011/09/17 05:53] dougster |
Line 412: | Line 412: | ||
<box 46% left round bluedark|Device Bankstick Downloads> | <box 46% left round bluedark|Device Bankstick Downloads> | ||
- | [[http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fpedalbox_v2%2FDevice_Config_Files%2FV-Amp%2FV-Amp.zip|Behringer V-Amp Series]] | + | {{:mcrozier:v-amp.zip|Behringer V-Amp Series}} |
</box> \\ | </box> \\ | ||
<box 46% left round|PC Editor> | <box 46% left round|PC Editor> | ||
- | [[http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fpedalbox_v2%2Feditor%2Fv2%2FPBEditor2.zip|Pedal Board Editor 2 v1.0]] \\ | + | {{:mcrozier:pbeditor2.zip|Pedal Board Editor 2 v1.0}} \\ |
Please note the editor requires a minimum of WinXP with .Net 3.5 \\ | Please note the editor requires a minimum of WinXP with .Net 3.5 \\ | ||
</box> | </box> | ||
<box 98% round|Docs> | <box 98% round|Docs> | ||
- | [[http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fcontrollers%2Fpedalbox_v2%2Fdocs%2FPB_Manual.pdf|The Complete Usage Manual]] | + | {{:mcrozier:pb_manual.pdf|The Complete Usage Manual}}</box> |
- | </box> | + | |
Line 687: | Line 686: | ||
{{mcrozier:pedal_board_max.jpg}} \\ | {{mcrozier:pedal_board_max.jpg}} \\ | ||
You know you want to build it! | You know you want to build it! | ||
