Next revision | Previous revision | ||
pedal_box:pc_editor_manual [2008/10/09 00:20] 127.0.0.1 external edit |
pedal_box:pc_editor_manual [2009/12/15 06:05] Durisian |
Line 8: | Line 8: | ||
In the not too distant future I plan to completely re-write it from the ground up - implementing some of the things I have learned along the way right from the start, rather than hacking them in place. But thats a long way off yet! | In the not too distant future I plan to completely re-write it from the ground up - implementing some of the things I have learned along the way right from the start, rather than hacking them in place. But thats a long way off yet! | ||
+ | 15/12/09 - | ||
+ | A new PC Editor is on the way (written in VB - I know, I know, but it's so much easier than java ^_^) \\ | ||
+ | It has some cool stuff - like: \\ | ||
+ | * ability to move items up and down the lists - and auto change the pedal/switch settings to match (sooo much simpler if you change your mind about the order of things) | ||
+ | * Entire Expression Pedal swapping | ||
+ | * Assign the same settings to a banked footswitch to the same number in all the banks | ||
+ | * Movable buttons on the footswitch screen allow for a basic visual representation of your footswitch layout | ||
+ | * + more | ||
+ | I have a few hickups though, namely with getting the MIDI side of things to work. | ||
+ | If anyone has experirnce with MIDI in VB - i'd love some help :-D | ||
======PB PC Editor Manual====== | ======PB PC Editor Manual====== | ||
Line 43: | Line 56: | ||
It also has facilities to save, export and upload data to the master bankstick. | It also has facilities to save, export and upload data to the master bankstick. | ||
- | {{pedal_box:pbpc_master_window.jpg}} | + | {{http://www.durisian.com/midibox/PB/images/pbpce_master.jpg}} |
**Device name** - Name of your Midibox PB harware | **Device name** - Name of your Midibox PB harware | ||
Line 205: | Line 218: | ||
====Overview==== | ====Overview==== | ||
- | {{pedal_box:pbpc_device_window.jpg}} | + | {{http://www.durisian.com/midibox/PB/images/pbpce_device.jpg}} |
Same as the Master Bankstick, all the information is displayed in a Tree. | Same as the Master Bankstick, all the information is displayed in a Tree. | ||
Line 314: | Line 327: | ||
=====History===== | =====History===== | ||
+ | * 0.6 - Updated to work with PB 2.5, + bug fixes | ||
* 0.5 - (2nd Beta) Improved MIDI In when using feedback, added magic number support, updated to new bankstick data format. | * 0.5 - (2nd Beta) Improved MIDI In when using feedback, added magic number support, updated to new bankstick data format. | ||
* 0.4 - Fixed some bugs | * 0.4 - Fixed some bugs |
