pickit2 [2009/01/25 19:06] chr0n1c |
pickit2 [2011/09/16 23:47] dougster |
Line 2: | Line 2: | ||
- | //This page is here in hopes of helping somone else avoid having to go through what i did in figuring it all out.// | + | //This page is here in hopes of helping somone else avoid having to go through what i did in figuring it all out.(--chr0n1c)// |
The Pickit2 USB Programmer WILL generate the required voltages for HVP programming of the chip. | The Pickit2 USB Programmer WILL generate the required voltages for HVP programming of the chip. | ||
- | It is possible to program you midibox core pic chip with this adapter and a Pickt2 from Microchip by following these steps. | + | It is possible to program your midibox core pic chip with this adapter and a Pickit2 from Microchip by following these steps. |
**1. BUILD THIS ICSP ADAPTER** | **1. BUILD THIS ICSP ADAPTER** | ||
Line 12: | Line 12: | ||
the jumper going to pin 38 of the pic18f452. | the jumper going to pin 38 of the pic18f452. | ||
- | ...will insert my schematic schreenshot here when i can get the uploader to work. | + | ...will insert my schematic screenshot here when i can get the uploader to work. |
Line 40: | Line 40: | ||
**9. PULL THE CHIP FROM THE PROGRAMMING ADAPTER AND INSERT IT TO YOUR MBHP_CORE.** | **9. PULL THE CHIP FROM THE PROGRAMMING ADAPTER AND INSERT IT TO YOUR MBHP_CORE.** | ||
- | **10. from here, there is plenty of other documents on the wiki describing the next steps...** | + | **10. from here, there is plenty of other documents on the wiki describing the next steps...** |
LINK: http://www.ucapps.de/mios_bootstrap.html | LINK: http://www.ucapps.de/mios_bootstrap.html | ||
+ | other forum posts that were helpful in this research... | ||
- | + | http://www.midibox.org/forum/index.php/topic,11754.0.html -- discussion of me starting to build a MBHP_CORE | |
- | other froum posts that were helpful in this research... | + | http://www.midibox.org/forum/index.php/topic,9831.0.html - discussion about HVP versus LVP |
- | http://www.midibox.org/forum/index.php/topic,11754.0.html -- dscussion of me starting to build a MBHP_CORE | + | http://www.midibox.org/forum/index.php/topic,10050.0.html - another discussion about HVP versus LVP |
- | http://www.midibox.org/forum/index.php/topic,9831.0.html - discussion about HVP versus LVP | + | |
- | http://www.midibox.org/forum/index.php/topic,10050.0.html - another discussion about HVP versus LVP | + | |
