pinheader
Differences
Link to this comparison view
Both sides previous revision Previous revision
Last revision Both sides next revision
pinheader [2016/06/07 18:08]
psykhaze
pinheader [2016/06/15 12:54]
psykhaze
Line 1: Line 1:
 ====== Pinheader ====== ====== Pinheader ======
-{{ ::​neonking:​pinheader.png?​direct&​500 |}}+{{ ::​neonking:​pinheader.png?​direct&​400|}}
 A pinheader is a basic connector to plug things on your PCB without having them soldered. A pinheader is a basic connector to plug things on your PCB without having them soldered.
 It can be **single or dual row** (SIL-DIL). The usual pitch, aka the distance between 2 pins is 2,54mm. It can be **single or dual row** (SIL-DIL). The usual pitch, aka the distance between 2 pins is 2,54mm.
 A pin header is designed to be splitted that you can have only the number of pins required to solder. A pin header is designed to be splitted that you can have only the number of pins required to solder.
pinheader.txt ยท Last modified: 2016/07/11 00:00 by psykhaze
