Both sides previous revision Previous revision | Last revision Both sides next revision | ||
questionable [2009/10/06 11:50] WickedBlade partial formatting fix (something with the italics not closed properly) |
questionable [2011/08/29 12:50] danalovett |
Line 113: | Line 113: | ||
**Consider the usefulness of a shift key:** I hadn't thought of it when I started designing the box, but Traktor can make use of a shift (modifier) key, so you should be able to have a number of your buttons do double duty, simply by adding a separate shift button. This could be especially useful if you're using the control surface to select tracks, etc. | **Consider the usefulness of a shift key:** I hadn't thought of it when I started designing the box, but Traktor can make use of a shift (modifier) key, so you should be able to have a number of your buttons do double duty, simply by adding a separate shift button. This could be especially useful if you're using the control surface to select tracks, etc. | ||
+ | [[http://editingwritingservices.org/article.php|article writing service]] | ||
