scs_pcb [2015/03/24 08:44] ilmenator added section about the encoder |
scs_pcb [2021/05/12 07:06] ilmenator [MIDIbox SCS Standard Control Surface module] link to repository updated |
Line 1: | Line 1: | ||
====== MIDIbox SCS Standard Control Surface module ====== | ====== MIDIbox SCS Standard Control Surface module ====== | ||
- | The SCS module implements a standard user interface that is available as a module in the MIOS codebase. It goes nicely with a 20x character LCD and connects to J10 on the core board. An application example can be found in [[http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Ftutorials%2F027_scs%2F|tutorial #027]]. | + | The SCS module implements a standard user interface that is available as a module in the MIOS codebase. It goes nicely with a 20x character LCD and connects to J10 on the core board. An application example can be found in [[https://github.com/midibox/mios32/tree/master/apps/tutorials/027_scs|tutorial #027]]. |
The PCB I have designed can accommodate three different types of switches: my favourite switches from [[16x4blm_pcb|Marquardt (6425 series)]], TK's favourites from ITT Schadow (D6 series) available at Reichelt, and the [[16x4blm_pcb|E-Switch TL1100 series]] (see e.g. MB SEQv4) can be used. | The PCB I have designed can accommodate three different types of switches: my favourite switches from [[16x4blm_pcb|Marquardt (6425 series)]], TK's favourites from ITT Schadow (D6 series) available at Reichelt, and the [[16x4blm_pcb|E-Switch TL1100 series]] (see e.g. MB SEQv4) can be used. | ||
Line 18: | Line 18: | ||
==== Where to buy? ==== | ==== Where to buy? ==== | ||
- | If you are interested in buying this, send a personal message (PM) to user //ilmenator// over at the [[http://midibox.org/forums/|MIDIbox forum]] (you have to register to be able to send PM). As of March 2015, I have PCBs available for 4,50€ each. | + | If you are interested in buying this, send a personal message (PM) to user //ilmenator// over at the [[http://midibox.org/forums/|MIDIbox forum]] (you have to register to be able to send PM). As of August 2020, I have PCBs available for 4,50€ each. |
===== Switches ===== | ===== Switches ===== |
