scs_pcb
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revisionLast revisionBoth sides next revision | ||
scs_pcb [2016/06/11 12:28] – [Where to buy?] updated availability ilmenator | scs_pcb [2021/05/12 07:07] – [Where to buy?] ilmenator | ||
Line 1: | Line 1: | ||
====== MIDIbox SCS Standard Control Surface module ====== | ====== MIDIbox SCS Standard Control Surface module ====== | ||
- | The SCS module implements a standard user interface that is available as a module in the MIOS codebase. It goes nicely with a 20x character LCD and connects to J10 on the core board. An application example can be found in [[http://svnmios.midibox.org/listing.php? | + | The SCS module implements a standard user interface that is available as a module in the MIOS codebase. It goes nicely with a 20x character LCD and connects to J10 on the core board. An application example can be found in [[https://github.com/midibox/ |
The PCB I have designed can accommodate three different types of switches: my favourite switches from [[16x4blm_pcb|Marquardt (6425 series)]], TK's favourites from ITT Schadow (D6 series) available at Reichelt, and the [[16x4blm_pcb|E-Switch TL1100 series]] (see e.g. MB SEQv4) can be used. | The PCB I have designed can accommodate three different types of switches: my favourite switches from [[16x4blm_pcb|Marquardt (6425 series)]], TK's favourites from ITT Schadow (D6 series) available at Reichelt, and the [[16x4blm_pcb|E-Switch TL1100 series]] (see e.g. MB SEQv4) can be used. | ||
Line 18: | Line 18: | ||
==== Where to buy? ==== | ==== Where to buy? ==== | ||
- | If you are interested in buying this, send a personal message (PM) to user // | + | If you are interested in buying this, send a personal message (PM) to user // |
===== Switches ===== | ===== Switches ===== |
scs_pcb.txt · Last modified: 2021/09/11 09:09 by ilmenator
