sensors [2016/06/15 07:40] psykhaze [Introduction] |
sensors [2016/06/15 07:42] psykhaze [Introduction] |
Line 11: | Line 11: | ||
Sensor-Wiki maintains a free list of possible sensors you could experiment with . For example the picture on the right is a EEG Active Electrode from the OpenEEG Project. A mind-controlled midibox ? who said that ? | Sensor-Wiki maintains a free list of possible sensors you could experiment with . For example the picture on the right is a EEG Active Electrode from the OpenEEG Project. A mind-controlled midibox ? who said that ? | ||
- | * http://www.sensorwiki.org/doku.php/sensors/introduction | + | * **[[http://www.sensorwiki.org/doku.php/sensors/introduction|SensorWiki]]** |
* [[https://en.wikipedia.org/wiki/List_of_sensors| Wikipedia page on sensors]] | * [[https://en.wikipedia.org/wiki/List_of_sensors| Wikipedia page on sensors]] | ||
* [[http://openeeg.sourceforge.net/doc/|Open EEG Project]] | * [[http://openeeg.sourceforge.net/doc/|Open EEG Project]] | ||
Line 19: | Line 20: | ||
===== Forum Topics ===== | ===== Forum Topics ===== | ||
- | * [[http://midibox.org/forums/topic/6057-connecting-non-10k-resistance-based-sensors/#comment-40071|How to connect Non-10k Resistance-based Sensors]] | ||
* [[http://midibox.org/forums/topic/12260-experimental-controllers-sensors-ribbons-et-cetera/#comment-110394|Experimental controllers-sensors-ribbons]] | * [[http://midibox.org/forums/topic/12260-experimental-controllers-sensors-ribbons-et-cetera/#comment-110394|Experimental controllers-sensors-ribbons]] | ||
+ | * [[http://midibox.org/forums/topic/17428-touch-button/|Touch Button]] | ||
* [[http://midibox.org/forums/topic/4906-distance-sensor-like-d-beam-controler/#comment-31901|About Distance Sensors]] | * [[http://midibox.org/forums/topic/4906-distance-sensor-like-d-beam-controler/#comment-31901|About Distance Sensors]] | ||
* [[http://midibox.org/forums/topic/19097-adafruit-touch-sensors/#comment-166581|AdaFruit touch Sensor]] | * [[http://midibox.org/forums/topic/19097-adafruit-touch-sensors/#comment-166581|AdaFruit touch Sensor]] | ||
+ | * [[http://midibox.org/forums/topic/4097-polyphonic-touchsensors|Polyphonic Touch sensors]] | ||
+ | * [[http://midibox.org/forums/topic/17221-ac-sensorizer-glove/|AC Sensorizer Glove]] | ||
* [[http://midibox.org/forums/topic/4906-distance-sensor-like-d-beam-controler/|Distance Sensor]] | * [[http://midibox.org/forums/topic/4906-distance-sensor-like-d-beam-controler/|Distance Sensor]] | ||
* [[http://midibox.org/forums/blogs/entry/100-sharp-infrared-distance-sensor/|Another Sharp Infrared Distance Sensor]] | * [[http://midibox.org/forums/blogs/entry/100-sharp-infrared-distance-sensor/|Another Sharp Infrared Distance Sensor]] | ||
- | * [[http://midibox.org/forums/topic/4097-polyphonic-touchsensors|Polyphonic Touch sensors]] | + | * [[http://midibox.org/forums/topic/6057-connecting-non-10k-resistance-based-sensors/#comment-40071|How to connect Non-10k Resistance-based Sensors]] |
- | * [[http://midibox.org/forums/topic/17221-ac-sensorizer-glove/|AC Sensorizer Glove]] | + | |
