====== Sensors ====== {{ :neonking:neuralelectrode.jpg?direct&300|}} ===== Introduction ===== Here some informations about various sensor-types and how to connect them to a midibox. Keep in mind that **most of sensors are analog , so they require an AINSER Module to be plugged as inputs to the Core Board**.If you're interested in working with sensors, you might also want to check out the [[ACSensorizer]]-Midibox project. Sensor-Wiki maintains a free list of possible sensors you could experiment with . For example the picture above is a EEG Active Electrode from the OpenEEG Project. A mind-controlled midibox ? who said that ? * http://www.sensorwiki.org/doku.php/sensors/introduction * http://openeeg.sourceforge.net/doc/ ===== Forum Topics ===== //FIXME : Correct Forum links// * How to connect Non-10k Resistance-based Sensors: http://www.midibox.org/forum/index.php?topic=6506.0 * What's the issue about linearity? http://www.midibox.org/forum/index.php?topic=6728.0 * About Distance Sensors: http://www.midibox.org/forum/index.php?topic=5270.0 * About TouchPads, SoftPots and other interesting stuff: http://www.midibox.org/forum/index.php?topic=5023.0 * Touch Sensors (as Buttons): http://www.midibox.org/forum/index.php?topic=9220.0 * How to connect Flex-Sensors: http://www.midibox.org/forum/index.php?topic=5388.0 * Accelerometers, Tilt-Sensors: http://www.midibox.org/forum/index.php?topic=1985.0 * About Ribbon-Controllers: http://www.midibox.org/forum/index.php?topic=9679.0
