Both sides previous revision Previous revision | Next revision Both sides next revision | ||
seq_v4l_mk._ii [2017/02/06 22:00] latigid_on [License] |
seq_v4l_mk._ii [2017/02/06 22:00] latigid_on [Firmware] |
Line 164: | Line 164: | ||
A sessions folder will be created on first use if one doesn't exist. If you're having trouble with the MIDI Input, please open the SESSIONS/DEF_V4L/MBSEQ_C.V4 file and change: | A sessions folder will be created on first use if one doesn't exist. If you're having trouble with the MIDI Input, please open the SESSIONS/DEF_V4L/MBSEQ_C.V4 file and change: | ||
- | MIDI_BUS_Options 0 0x00 | + | MIDI_BUS_Options 0 0x00 |
to | to | ||
- | MIDI_BUS_Options 0 0x01 | + | MIDI_BUS_Options 0 0x01 |
