smithy
Differences
Link to this comparison view
Both sides previous revision Previous revision
smithy [2010/02/03 20:02]
smithy
smithy [2010/02/03 22:39] (current)
smithy
Line 36: Line 36:
 |EEPROM |24C04 |1 |DIP8 |IC2 |[[https://​ie.mouser.com/​Search/​ProductDetail.aspx?​R=CAT24C04LI-Gvirtualkey69800000virtualkey698-CAT24C04LI-G|Mouser]]| |EEPROM |24C04 |1 |DIP8 |IC2 |[[https://​ie.mouser.com/​Search/​ProductDetail.aspx?​R=CAT24C04LI-Gvirtualkey69800000virtualkey698-CAT24C04LI-G|Mouser]]|
 |Resistor |220 Ohm |15 |0207 |R1 – R3, R6 – R8, R11 – R13, R16, R18, R31 – R33, R39|[[http://​ie.mouser.com/​ProductDetail/​Vishay-Dale/​CCF07220RGKR36/?​qs=sGAEpiMZZMtMTfExsNintdVS3lMdL61e1mPZHVrGnQE%3d|Mouser]]| |Resistor |220 Ohm |15 |0207 |R1 – R3, R6 – R8, R11 – R13, R16, R18, R31 – R33, R39|[[http://​ie.mouser.com/​ProductDetail/​Vishay-Dale/​CCF07220RGKR36/?​qs=sGAEpiMZZMtMTfExsNintdVS3lMdL61e1mPZHVrGnQE%3d|Mouser]]|
-|Resistor |**1k Ohm(*1)** |18 |0207 |R5,​ R10, R15, R17, R20 - R30, R35, R38, R40 |[[https://​ie.mouser.com/​Search/​ProductDetail.aspx?​R=CCF071K00GKE36virtualkey61300000virtualkey71-CCF071K00GKE36|Mouser]]|+|Resistor |**1k Ohm(*1)** |18 |0207 |R5,​ R10, R15, R17, R20 - R30, R35, R38, R40 |[[https://​ie.mouser.com/​Search/​ProductDetail.aspx?​R=CCF551K00FKE36virtualkey61300000virtualkey71-CCF551K00FKE36|Mouser]]|
 |Resistor |27 Ohm |2 |0207 |R36,​ R37 |[[https://​ie.mouser.com/​Search/​ProductDetail.aspx?​R=MF1%2f4DCT52R27R0Fvirtualkey66000000virtualkey660-MF1%2f4DCT52R27R0F|Mouser]]| |Resistor |27 Ohm |2 |0207 |R36,​ R37 |[[https://​ie.mouser.com/​Search/​ProductDetail.aspx?​R=MF1%2f4DCT52R27R0Fvirtualkey66000000virtualkey660-MF1%2f4DCT52R27R0F|Mouser]]|
 |Resistor |4.7k Ohm |5 |0207 |R4,​ R9, R14, R19, R34 |[[https://​ie.mouser.com/​Search/​ProductDetail.aspx?​R=MF1%2f4DCT52R4701Fvirtualkey66000000virtualkey660-MF1%2f4DCT52R4701F|Mouser]]| |Resistor |4.7k Ohm |5 |0207 |R4,​ R9, R14, R19, R34 |[[https://​ie.mouser.com/​Search/​ProductDetail.aspx?​R=MF1%2f4DCT52R4701Fvirtualkey66000000virtualkey660-MF1%2f4DCT52R4701F|Mouser]]|
smithy.txt · Last modified: 2010/02/03 22:39 by smithy
