Both sides previous revision Previous revision | Next revision Both sides next revision | ||
smithy [2010/02/03 19:55] smithy |
smithy [2010/02/03 19:57] smithy |
Line 44: | Line 44: | ||
|DIP8 IC Socket |8 Pin |6 |7.62mm |IC2, IC8 - IC12|[[https://www.mouser.com/Search/ProductDetail.aspx?R=4808-3004-CPvirtualkey51750000virtualkey517-4808-3004-CP|Mouser]]| | |DIP8 IC Socket |8 Pin |6 |7.62mm |IC2, IC8 - IC12|[[https://www.mouser.com/Search/ProductDetail.aspx?R=4808-3004-CPvirtualkey51750000virtualkey517-4808-3004-CP|Mouser]]| | ||
|DIP14 IC Socket |14 Pin |5 |7.62mm |IC3 - IC7|[[https://www.mouser.com/Search/ProductDetail.aspx?R=4814-3000-CPvirtualkey51750000virtualkey517-4814-3000-CP|Mouser]]| | |DIP14 IC Socket |14 Pin |5 |7.62mm |IC3 - IC7|[[https://www.mouser.com/Search/ProductDetail.aspx?R=4814-3000-CPvirtualkey51750000virtualkey517-4814-3000-CP|Mouser]]| | ||
- | |SIL Header |16 Pins |- |- | | | ||
(*1) Note that 11 of the resistor listed as 1k in the above list (R21 - R30 and R40) are for the LEDs. The values for these resistors depends on the color of LEDs you plan to use and the brightness you wish to achieve. Suggested values: | (*1) Note that 11 of the resistor listed as 1k in the above list (R21 - R30 and R40) are for the LEDs. The values for these resistors depends on the color of LEDs you plan to use and the brightness you wish to achieve. Suggested values: |
