smithy [2010/02/03 19:55] smithy |
smithy [2010/02/03 22:39] smithy |
Line 20: | Line 20: | ||
|Front Panel & Back Panel|1|See Note|[[http://www.schaeffer-ag.de/|Schaeffer]]|Check Forum| | |Front Panel & Back Panel|1|See Note|[[http://www.schaeffer-ag.de/|Schaeffer]]|Check Forum| | ||
==== GM5X5X5 Part list ==== | ==== GM5X5X5 Part list ==== | ||
+ | Click [[http://www.mouser.com/ProjectManager/ProjectDetail.aspx?AccessID=35fe3f02e7|here]] to view the full Mouser Cart/Project Manger (excludes Headers/Pins) | ||
|**Part**|**Value**|**Count**|**Footprint/\\ lead spacing**|**Part #**|**Supplier**| | |**Part**|**Value**|**Count**|**Footprint/\\ lead spacing**|**Part #**|**Supplier**| | ||
Line 34: | Line 36: | ||
|EEPROM |24C04 |1 |DIP8 |IC2 |[[https://ie.mouser.com/Search/ProductDetail.aspx?R=CAT24C04LI-Gvirtualkey69800000virtualkey698-CAT24C04LI-G|Mouser]]| | |EEPROM |24C04 |1 |DIP8 |IC2 |[[https://ie.mouser.com/Search/ProductDetail.aspx?R=CAT24C04LI-Gvirtualkey69800000virtualkey698-CAT24C04LI-G|Mouser]]| | ||
|Resistor |220 Ohm |15 |0207 |R1 – R3, R6 – R8, R11 – R13, R16, R18, R31 – R33, R39|[[http://ie.mouser.com/ProductDetail/Vishay-Dale/CCF07220RGKR36/?qs=sGAEpiMZZMtMTfExsNintdVS3lMdL61e1mPZHVrGnQE%3d|Mouser]]| | |Resistor |220 Ohm |15 |0207 |R1 – R3, R6 – R8, R11 – R13, R16, R18, R31 – R33, R39|[[http://ie.mouser.com/ProductDetail/Vishay-Dale/CCF07220RGKR36/?qs=sGAEpiMZZMtMTfExsNintdVS3lMdL61e1mPZHVrGnQE%3d|Mouser]]| | ||
- | |Resistor |**1k Ohm(*1)** |18 |0207 |R5, R10, R15, R17, R20 - R30, R35, R38, R40 |[[https://ie.mouser.com/Search/ProductDetail.aspx?R=CCF071K00GKE36virtualkey61300000virtualkey71-CCF071K00GKE36|Mouser]]| | + | |Resistor |**1k Ohm(*1)** |18 |0207 |R5, R10, R15, R17, R20 - R30, R35, R38, R40 |[[https://ie.mouser.com/Search/ProductDetail.aspx?R=CCF551K00FKE36virtualkey61300000virtualkey71-CCF551K00FKE36|Mouser]]| |
|Resistor |27 Ohm |2 |0207 |R36, R37 |[[https://ie.mouser.com/Search/ProductDetail.aspx?R=MF1%2f4DCT52R27R0Fvirtualkey66000000virtualkey660-MF1%2f4DCT52R27R0F|Mouser]]| | |Resistor |27 Ohm |2 |0207 |R36, R37 |[[https://ie.mouser.com/Search/ProductDetail.aspx?R=MF1%2f4DCT52R27R0Fvirtualkey66000000virtualkey660-MF1%2f4DCT52R27R0F|Mouser]]| | ||
|Resistor |4.7k Ohm |5 |0207 |R4, R9, R14, R19, R34 |[[https://ie.mouser.com/Search/ProductDetail.aspx?R=MF1%2f4DCT52R4701Fvirtualkey66000000virtualkey660-MF1%2f4DCT52R4701F|Mouser]]| | |Resistor |4.7k Ohm |5 |0207 |R4, R9, R14, R19, R34 |[[https://ie.mouser.com/Search/ProductDetail.aspx?R=MF1%2f4DCT52R4701Fvirtualkey66000000virtualkey660-MF1%2f4DCT52R4701F|Mouser]]| | ||
Line 44: | Line 46: | ||
|DIP8 IC Socket |8 Pin |6 |7.62mm |IC2, IC8 - IC12|[[https://www.mouser.com/Search/ProductDetail.aspx?R=4808-3004-CPvirtualkey51750000virtualkey517-4808-3004-CP|Mouser]]| | |DIP8 IC Socket |8 Pin |6 |7.62mm |IC2, IC8 - IC12|[[https://www.mouser.com/Search/ProductDetail.aspx?R=4808-3004-CPvirtualkey51750000virtualkey517-4808-3004-CP|Mouser]]| | ||
|DIP14 IC Socket |14 Pin |5 |7.62mm |IC3 - IC7|[[https://www.mouser.com/Search/ProductDetail.aspx?R=4814-3000-CPvirtualkey51750000virtualkey517-4814-3000-CP|Mouser]]| | |DIP14 IC Socket |14 Pin |5 |7.62mm |IC3 - IC7|[[https://www.mouser.com/Search/ProductDetail.aspx?R=4814-3000-CPvirtualkey51750000virtualkey517-4814-3000-CP|Mouser]]| | ||
- | |SIL Header |16 Pins |- |- | | | ||
(*1) Note that 11 of the resistor listed as 1k in the above list (R21 - R30 and R40) are for the LEDs. The values for these resistors depends on the color of LEDs you plan to use and the brightness you wish to achieve. Suggested values: | (*1) Note that 11 of the resistor listed as 1k in the above list (R21 - R30 and R40) are for the LEDs. The values for these resistors depends on the color of LEDs you plan to use and the brightness you wish to achieve. Suggested values: |
