speakjet_breadboard_construction [2016/06/14 02:13] psykhaze [SpeakJet IIC Module Construction] |
speakjet_breadboard_construction [2016/06/15 07:56] psykhaze [4. Parts List] |
Line 1: | Line 1: | ||
====== SpeakJet IIC Module Construction ====== | ====== SpeakJet IIC Module Construction ====== | ||
+ | {{http://www.audiocommander.de/picBrowser/galleries/070305_kII/IMG_7773.jpg?direct600}} | ||
* [[http://www.ucapps.de/mbhp_iic_speakjet.html|Official Ucapps IIC SpeakJet Module Page]] <sup>uCApps</sup> | * [[http://www.ucapps.de/mbhp_iic_speakjet.html|Official Ucapps IIC SpeakJet Module Page]] <sup>uCApps</sup> | ||
Line 11: | Line 13: | ||
The RS232 Section is optional. | The RS232 Section is optional. | ||
- | :!: **Never connect RS232 signals from your PC directly to the SpeakJet!\\ | + | :!: **Never connect RS232 signals from your PC directly to the SpeakJet!** :!: |
- | Because RS232 is operated with 12V and the SpeakJet just deals with 5V, you will likely damage it!** | + | |
+ | //Because RS232 is operated with 12V and the SpeakJet just deals with 5V, you will likely damage it!// | ||
===== 2. Hardware Setup ===== | ===== 2. Hardware Setup ===== | ||
Line 18: | Line 21: | ||
=== Full Setup === | === Full Setup === | ||
- | To turn the SpeakJet IIC Module into a fully operateable synthesizer, you need this:__\\ | + | //To turn the SpeakJet IIC Module into a fully operateable synthesizer, you need this:// |
* 1 Core-Module (PIC18F) | * 1 Core-Module (PIC18F) | ||
* 1 SpeakJet IIC Module (PIC16F, MAX232 and SpeakJet) | * 1 SpeakJet IIC Module (PIC16F, MAX232 and SpeakJet) | ||
Line 25: | Line 29: | ||
=== Construction Steps === | === Construction Steps === | ||
+ | {{http://www.audiocommander.de/picBrowser/galleries/070305_kII/IMG_7758.jpg?400x300}} | ||
- Soldering the core module | - Soldering the core module | ||
Line 39: | Line 45: | ||
- | ===== 4. Parts ListParts ===== | + | ===== 4. Parts List ===== |
+ | ^Part ^Value ^Type ^ Qty ^ Mouser Ref ^ | ||
+ | |IC1 |SpeakJet |SpeakJet |1 |/ | | ||
+ | |IC2 |PIC 16F88|PIC |1 |579-PIC16F88-I/P| | ||
+ | |IC3 |MAX 232 |MAX 232 EEPE |1 |700-MAX232EEPE | | ||
+ | |Q1 |20MHz |Q |1 | | | ||
+ | |R1 |220 |Resistor |1 |291-220-RC | | ||
+ | |R2,R3 |10k |Resistor |2 |291-10k-RC | | ||
+ | |R5,R6 |27k |Resistor |2 |291-27k-RC | | ||
+ | |R4 |27k |Resistor |1 |291-50k-RC | | ||
+ | |C1,C2 |15pF |Capacitor Ceram |2 | | | ||
+ | |C12,C13 |10nF |Capacitor Ceram |2 | | | ||
+ | |C4,C6-10 |100nF |Capacitor Ceram |5 | | | ||
+ | |C3,C5,C11 |10µF/16V |Capacitor Elec |3 | | | ||
+ | **Jumpers** | ||
+ | * **J1** IIC | ||
+ | * **J2** ID | ||
+ | * **J3** Line-Out (unfiltered) | ||
+ | * **J41** 1: SJ Out, 2: D0 (Ready), 3: D1 (Speaking) | ||
+ | * **J5** Line-Out (hiPass-filtered) | ||
+ | * **J6** RS232: PC I/O | ||
+ | * **J7** SJ Event Inputs (see Datasheet!) | ||
- | * IC1 SpeakJet | ||
- | * IC2 PIC 16F88 | ||
- | * IC3 MAX 232 EEPE (! a MAX 232 EPE did not work in my setup!) | ||
- | * Q1 20 MHz | ||
- | * R1 220 Ω | ||
- | * R2,R3 10 kΩ | ||
- | * R4 50 kΩ | ||
- | * R5,R6 27 kΩ | ||
- | * - 0 Ω (Bridge) | ||
- | * C1,C2 15 pF | ||
- | * C3,C5,C11 10 µF | ||
- | * C4,C6-10 100 nF | ||
- | * C12,C13 0.01µF = 10 nF | ||
- | * J1 IIC | ||
- | * J2 ID | ||
- | * J3 Line-Out (unfiltered) | ||
- | * J41 1: SJ Out, 2: D0 (Ready), 3: D1 (Speaking) | ||
- | * J5 Line-Out (hiPass-filtered) | ||
- | * J6 RS232: PC I/O | ||
- | * J7 SJ Event Inputs (see Datasheet!) | ||
- | * some additional parts like wires, jacks and plugs are not listed... | ||
===== 6. Buying Speakjet IC ===== | ===== 6. Buying Speakjet IC ===== | ||
Line 70: | Line 78: | ||
* [[http://www.lextronic.fr/P3124-circuit-integre-speakjet.html|Lextronic France]] | * [[http://www.lextronic.fr/P3124-circuit-integre-speakjet.html|Lextronic France]] | ||
- | ====== 7. Soldering the Board ====== | + | ===== 7. Soldering the Board ===== |
The current board version v1.3 has a lot less backside cabling, is easier to solder, parts have all convenient sizes and the board dimensions are landscape; similar to the MBHP-DIN/DOUT PCBs.\\ | The current board version v1.3 has a lot less backside cabling, is easier to solder, parts have all convenient sizes and the board dimensions are landscape; similar to the MBHP-DIN/DOUT PCBs.\\ | ||
Line 80: | Line 88: | ||
{{http://www.audiocommander.de/picBrowser/galleries/070305_kII/IMG_7760.jpg?266x178}}{{http://www.audiocommander.de/picBrowser/galleries/070305_kII/IMG_7761.jpg?266x178}}{{http://www.audiocommander.de/picBrowser/galleries/070305_kII/IMG_7769.jpg?266x178}} | {{http://www.audiocommander.de/picBrowser/galleries/070305_kII/IMG_7760.jpg?266x178}}{{http://www.audiocommander.de/picBrowser/galleries/070305_kII/IMG_7761.jpg?266x178}}{{http://www.audiocommander.de/picBrowser/galleries/070305_kII/IMG_7769.jpg?266x178}} | ||
[[http://www.audiocommander.de/picBrowser/picBrowser.php?go=galleries/070305_kII&thumbs=1&thumbsize=XL|Here is a Picture Gallery v1.3]] that shows the process of soldering the breadboard along with some final pictures from different views. | [[http://www.audiocommander.de/picBrowser/picBrowser.php?go=galleries/070305_kII&thumbs=1&thumbsize=XL|Here is a Picture Gallery v1.3]] that shows the process of soldering the breadboard along with some final pictures from different views. | ||
+ | [[http://www.audiocommander.de/picBrowser/picBrowser.php?go=galleries/060600_kII_MIOS&thumbs=0|Picture Gallery v1.0 (for historic reasons only)]] | ||
- | [[http://www.audiocommander.de/picBrowser/picBrowser.php?go=galleries/060600_kII_MIOS&thumbs=0|Here is a Picture Gallery v1.0]] (for historic reasons only) | + | Don't cut the legs at once, use them to build the paths at the bottom!I tried to make the board as small as possible, but there should be enough space to add additional pins if necessary. |
- | Don't cut the legs at once, use them to build the paths at the bottom! | + | |
- | I tried to make the board as small as possible, but there should be enough space to add additional pins if necessary. | + | |
- | ====== 8. Burning the PIC16F Firmware ====== | + | ===== 8. Burning the PIC16F Firmware ===== |
You'll need the [[pic_programmer_modules|MBHP-Burner]] and build an adaptor from 40pin to 18pin: | You'll need the [[pic_programmer_modules|MBHP-Burner]] and build an adaptor from 40pin to 18pin: |
