speakjet_breadboard_construction
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
Last revision Both sides next revision
speakjet_breadboard_construction [2016/06/14 02:27]
psykhaze [4. Parts ListParts]
speakjet_breadboard_construction [2016/06/14 03:36]
psykhaze [4. Parts List]
Line 47: Line 47:
 ===== 4. Parts List ===== ===== 4. Parts List =====
-^Part         ​^Value ​   ^Type                ^ Qty ^Package ​^ Mouser Ref     ^ +^Part         ​^Value ​   ^Type                ^ Qty ^ Mouser Ref     ^
-|IC1          |SpeakJet |SpeakJet ​           |1    ​|DIL16 ​  |/               | +|IC1          |SpeakJet |SpeakJet ​           |1    |/               |
-|IC2          |PIC 16F88|74HC595N ​           ​|1    ​|DIL16 ​  |595-SN74HC595N ​ | +|IC2          |PIC 16F88|PIC                 |1    |595-SN74HC595N ​ |
-|Q1           ​|20MHz ​   |Q                   ​|1 ​   ​|Q       |                | +|IC3          |MAX 232  |MAX 232 EEPE        |1    |700-MAX232EEPE ​ |
-|R1           ​|220 ​     |Resistor ​           |1    ​|        ​|291-220-RC ​     |     +|Q1           ​|20MHz ​   |Q                   ​|1 ​   |                |
-|R2,​R3 ​       |10k      |Resistor ​           |2    ​|        ​|291-10k-RC ​     | +|R1           ​|220 ​     |Resistor ​           |1    |291-220-RC ​     |
-|R5,​R6 ​       |27k      |Resistor ​           |2    ​|        ​|291-27k-RC ​     | +|R2,​R3 ​       |10k      |Resistor ​           |2    |291-10k-RC ​     |
-|R4           ​|27k ​     |Resistor ​           |1    ​|        ​|291-50k-RC ​     | +|R5,​R6 ​       |27k      |Resistor ​           |2    |291-27k-RC ​     |
-|C1,​C2 ​       |15pF     ​|Capacitor Ceram     ​|2 ​   ​|        ​|                | +|R4           ​|27k ​     |Resistor ​           |1    |291-50k-RC ​     |
-|C12,​C13 ​     |10nF     ​|Capacitor Ceram     ​|2 ​   ​|        ​|                | +|C1,​C2 ​       |15pF     ​|Capacitor Ceram     ​|2 ​   |                |
-|C4,​C6-10 ​    ​|100nF ​   |Capacitor Ceram     ​|5 ​   ​|        ​|                | +|C12,​C13 ​     |10nF     ​|Capacitor Ceram     ​|2 ​   |                |
-|C3,​C5,​C11 ​   |10µF/16V |Capacitor Elec      |3    ​|        ​|                |+|C4,​C6-10 ​    ​|100nF ​   |Capacitor Ceram     ​|5 ​   |                |
 +|C3,​C5,​C11 ​   |10µF/16V |Capacitor Elec      |3    |                |
 **Jumpers** **Jumpers**
-  ​* J1 IIC +
-  * J2 ID +  * **J1** IIC
-  * J3 Line-Out (unfiltered) +  ​* **J2** ID
-  * J41 1: SJ Out, 2: D0 (Ready), 3: D1 (Speaking) +  ​* **J3** Line-Out (unfiltered)
-  * J5 Line-Out (hiPass-filtered) +  ​* **J41** 1: SJ Out, 2: D0 (Ready), 3: D1 (Speaking)
-  * J6 RS232: PC I/O +  ​* **J5** Line-Out (hiPass-filtered)
-  * J7 SJ Event Inputs (see Datasheet!) +  ​* **J6** RS232: PC I/O
-  * some additional parts like wires, jacks and plugs are not listed...+  ​* **J7** SJ Event Inputs (see Datasheet!)
 ===== 6. Buying Speakjet IC ===== ===== 6. Buying Speakjet IC =====
Line 76: Line 78:
   * [[http://​www.lextronic.fr/​P3124-circuit-integre-speakjet.html|Lextronic France]]   * [[http://​www.lextronic.fr/​P3124-circuit-integre-speakjet.html|Lextronic France]]
-====== 7. Soldering the Board ======+===== 7. Soldering the Board =====
 The current board version v1.3 has a lot less backside cabling, is easier to solder, parts have all convenient sizes and the board dimensions are landscape; similar to the MBHP-DIN/​DOUT PCBs.\\ The current board version v1.3 has a lot less backside cabling, is easier to solder, parts have all convenient sizes and the board dimensions are landscape; similar to the MBHP-DIN/​DOUT PCBs.\\
Line 86: Line 88:
 {{http://​www.audiocommander.de/​picBrowser/​galleries/​070305_kII/​IMG_7760.jpg?​266x178}}{{http://​www.audiocommander.de/​picBrowser/​galleries/​070305_kII/​IMG_7761.jpg?​266x178}}{{http://​www.audiocommander.de/​picBrowser/​galleries/​070305_kII/​IMG_7769.jpg?​266x178}} {{http://​www.audiocommander.de/​picBrowser/​galleries/​070305_kII/​IMG_7760.jpg?​266x178}}{{http://​www.audiocommander.de/​picBrowser/​galleries/​070305_kII/​IMG_7761.jpg?​266x178}}{{http://​www.audiocommander.de/​picBrowser/​galleries/​070305_kII/​IMG_7769.jpg?​266x178}}
 [[http://​www.audiocommander.de/​picBrowser/​picBrowser.php?​go=galleries/​070305_kII&​thumbs=1&​thumbsize=XL|Here is a Picture Gallery v1.3]] that shows the process of soldering the breadboard along with some final pictures from different views. [[http://​www.audiocommander.de/​picBrowser/​picBrowser.php?​go=galleries/​070305_kII&​thumbs=1&​thumbsize=XL|Here is a Picture Gallery v1.3]] that shows the process of soldering the breadboard along with some final pictures from different views.
 +[[http://​www.audiocommander.de/​picBrowser/​picBrowser.php?​go=galleries/​060600_kII_MIOS&​thumbs=0|Picture Gallery v1.0 (for historic reasons only)]] ​
-[[http://​www.audiocommander.de/​picBrowser/​picBrowser.php?​go=galleries/​060600_kII_MIOS&​thumbs=0|Here is a Picture Gallery v1.0]] (for historic reasons only) +Don't cut the legs at once, use them to build the paths at the bottom!I tried to make the board as small as possible, but there should be enough space to add additional pins if necessary.
-Don't cut the legs at once, use them to build the paths at the bottom! +
-I tried to make the board as small as possible, but there should be enough space to add additional pins if necessary.+
-====== 8. Burning the PIC16F Firmware ​======+===== 8. Burning the PIC16F Firmware =====
 You'll need the [[pic_programmer_modules|MBHP-Burner]] and build an adaptor from 40pin to 18pin: You'll need the [[pic_programmer_modules|MBHP-Burner]] and build an adaptor from 40pin to 18pin:
speakjet_breadboard_construction.txt · Last modified: 2016/06/15 07:56 by psykhaze
