Both sides previous revision Previous revision | Next revision Both sides next revision | ||
speakjet_breadboard_construction [2016/06/14 02:32] psykhaze [4. Parts List] |
speakjet_breadboard_construction [2016/06/14 02:33] psykhaze |
Line 78: | Line 78: | ||
* [[http://www.lextronic.fr/P3124-circuit-integre-speakjet.html|Lextronic France]] | * [[http://www.lextronic.fr/P3124-circuit-integre-speakjet.html|Lextronic France]] | ||
- | ====== 7. Soldering the Board ====== | + | ===== 7. Soldering the Board ===== |
The current board version v1.3 has a lot less backside cabling, is easier to solder, parts have all convenient sizes and the board dimensions are landscape; similar to the MBHP-DIN/DOUT PCBs.\\ | The current board version v1.3 has a lot less backside cabling, is easier to solder, parts have all convenient sizes and the board dimensions are landscape; similar to the MBHP-DIN/DOUT PCBs.\\ | ||
Line 88: | Line 88: | ||
{{http://www.audiocommander.de/picBrowser/galleries/070305_kII/IMG_7760.jpg?266x178}}{{http://www.audiocommander.de/picBrowser/galleries/070305_kII/IMG_7761.jpg?266x178}}{{http://www.audiocommander.de/picBrowser/galleries/070305_kII/IMG_7769.jpg?266x178}} | {{http://www.audiocommander.de/picBrowser/galleries/070305_kII/IMG_7760.jpg?266x178}}{{http://www.audiocommander.de/picBrowser/galleries/070305_kII/IMG_7761.jpg?266x178}}{{http://www.audiocommander.de/picBrowser/galleries/070305_kII/IMG_7769.jpg?266x178}} | ||
[[http://www.audiocommander.de/picBrowser/picBrowser.php?go=galleries/070305_kII&thumbs=1&thumbsize=XL|Here is a Picture Gallery v1.3]] that shows the process of soldering the breadboard along with some final pictures from different views. | [[http://www.audiocommander.de/picBrowser/picBrowser.php?go=galleries/070305_kII&thumbs=1&thumbsize=XL|Here is a Picture Gallery v1.3]] that shows the process of soldering the breadboard along with some final pictures from different views. | ||
+ | [[http://www.audiocommander.de/picBrowser/picBrowser.php?go=galleries/060600_kII_MIOS&thumbs=0|Picture Gallery v1.0 (for historic reasons only)]] | ||
- | [[http://www.audiocommander.de/picBrowser/picBrowser.php?go=galleries/060600_kII_MIOS&thumbs=0|Here is a Picture Gallery v1.0]] (for historic reasons only) | + | Don't cut the legs at once, use them to build the paths at the bottom!I tried to make the board as small as possible, but there should be enough space to add additional pins if necessary. |
- | Don't cut the legs at once, use them to build the paths at the bottom! | + | |
- | I tried to make the board as small as possible, but there should be enough space to add additional pins if necessary. | + | |
- | ====== 8. Burning the PIC16F Firmware ====== | + | ===== 8. Burning the PIC16F Firmware ===== |
You'll need the [[pic_programmer_modules|MBHP-Burner]] and build an adaptor from 40pin to 18pin: | You'll need the [[pic_programmer_modules|MBHP-Burner]] and build an adaptor from 40pin to 18pin: |
