speakjet_definition_list
SCP and MSA #defines for the SpeakJet
ImportantNote:
This file is currently under development and can change radically!
Maybe you want to wait some days until this note disappears to add your SJ-Definitions
It can be used for your C-based MBHP_IIC_SpeakJet Project:
Feel free to edit and add defines!
/* * IIC_SpeakJetDefines.h * kII.2 * * Created by Michael Markert, audiocommander.de on 20.05.06 * Based on Speakjet control codes from July 27, 2004 version of Speakjet Manual * and ASM-Version of Doug Elliott, VA3DAE * * Released under CreativeCommons 2.5 by-nc-sa * http://creativecommons.org/licenses/by-nc-sa/2.5/ * */ #ifndef _IIC_SPEAKJETDEFINES_H #define _IIC_SPEAKJETDEFINES_H // ********* SPEAKJET MIDI ASSIGNMENTS * // #ifdef _DEBUG_C #pragma mark - #pragma mark SPEAKJET MIDI ASSIGNMENTS #endif // MIDI ASSIGNMENTS // optimized for KORG microKONTROL #define SJCC_PHRASE 20 // pads 1 - 8: call phrase #define SJCC_PHRASE0 21 #define SJCC_PHRASE1 22 #define SJCC_PHRASE2 23 #define SJCC_PHRASE3 24 #define SJCC_PHRASE4 25 #define SJCC_PHRASE5 26 #define SJCC_PHRASE6 27 #define SJCC_PHRASE7 28 // pads 9 - 12: slow/low/high/fast #define SJCC_NEXT_SLOW 29 #define SJCC_NEXT_LOW 30 #define SJCC_NEXT_HIGH 31 #define SJCC_NEXT_FAST 32 // pads 13 - 16: pause 0(0ms) / 1(100ms) / 2(200ms) / 3(700ms) #define SJCC_PAUSE0 33 #define SJCC_PAUSE1 34 #define SJCC_PAUSE2 35 #define SJCC_PAUSE3 36 // Encoders 1 - 5: OSCx Level #define SJCC_OSC1_LVL 101 #define SJCC_OSC2_LVL 102 #define SJCC_OSC3_LVL 103 #define SJCC_OSC4_LVL 104 #define SJCC_OSC5_LVL 105 // Sliders 1 - 5: OSCx Frequency #define SJCC_OSC1_FREQ 111 #define SJCC_OSC2_FREQ 112 #define SJCC_OSC3_FREQ 113 #define SJCC_OSC4_FREQ 114 #define SJCC_OSC5_FREQ 115 // Encoder 6 - 8: ENV CTR / DIST / SPEED #define SJCC_ENV_TYPE 106 #define SJCC_DISTORTION 107 #define SJCC_BEND 108 // Slider 6 - 8: BEND / NEXT LOUD / MASTER VOL #define SJCC_SPEED 116 #define SJCC_NEXT_LOUD 117 #define SJCC_MASTER_VOL 118 // Joystick X: Pitch // Joystick Y: Bend // not used, but implemented: #define SJCC_PITCH 255 // ********* SPEAKJET SCP REGISTERS **** // // SCP Registers & MAX Values #ifdef _DEBUG_C #pragma mark - #pragma mark SCP REGISTERS & MAX VALUES #endif // Envelope #define SCP_ENV_FREQ 0 #define SCP_ENV_CTRL 8 // ENVType (send ENVType + ENVState!) #define SCP_ENV_SAW 0x0 #define SCP_ENV_SINE 0x1 #define SCP_ENV_TRIANGLE 0x2 #define SCP_ENV_SQUARE 0x3 // ENVState (send ENVType + ENVState!) #define SCP_ENV_OSC123 0x40 #define SCP_ENV_OSC45 0x80 // Oscillators #define SCP_OSC1_FREQ 1 #define SCP_OSC2_FREQ 2 #define SCP_OSC3_FREQ 3 #define SCP_OSC4_FREQ 4 #define SCP_OSC5_FREQ 5 #define SCP_FREQ_MAX 3999 #define SCP_OSC1_LEVEL 11 #define SCP_OSC2_LEVEL 12 #define SCP_OSC3_LEVEL 13 #define SCP_OSC4_LEVEL 14 #define SCP_OSC5_LEVEL 15 #define SCP_LEVEL_MAX 31 // 63 MAX for Mixer 1 // Distortion #define SCP_DISTORTION 6 #define SCP_DISTORTION_MAX 255 // Master #define SCP_MASTER_VOLUME 7 #define SCP_MASTER_VOLUME_MAX 255 // ********* SPEAKJET SCP ************* // // Serial Control Protocol #ifdef _DEBUG_C #pragma mark - #pragma mark SCP #endif // escape character ('\\') 0x5C to enter SCP Mode #define SCP_ESCAPE 0x5C #define SCP_SEL0 0 #define SCP_SEL1 1 #define SCP_SEL2 2 #define SCP_SEL3 3 #define SCP_SEL4 4 #define SCP_SEL5 5 #define SCP_SEL6 6 #define SCP_SEL7 7 #define SCP_EXIT 'X' #define SCP_READY 'V' #define SCP_CLEAR_BUFFER 'R' #define SCP_START 'T' #define SCP_STOP 'S' #define SCP_MEMTYPE 'H' #define SCP_MEMADDR 'J' #define SCP_MEMWRT 'N' #define SCP_RESET 'W' // ********* SPEAKJET MSA ************* // // Mathmatical Sound Architecture #ifdef _DEBUG_C #pragma mark - #pragma mark MSA Control Codes #endif // 0 - 31 CONTROL CODES #define MSA_PAUSE0 0 #define MSA_PAUSE1 1 #define MSA_PAUSE2 2 #define MSA_PAUSE3 3 #define MSA_PAUSE4 4 #define MSA_PAUSE5 5 #define MSA_PAUSE6 6 #define MSA_NEXTFAST 7 #define MSA_NEXTSLOW 8 #define MSA_NEXTHIGH 14 #define MSA_NEXTLOW 15 #define MSA_WAIT 16 #define MSA_VOLUME 20 #define MSA_SPEED 21 #define MSA_PITCH 22 #define MSA_BEND 23 #define MSA_PORTCTR 24 #define MSA_PORT 25 #define MSA_REPEAT 26 #define MSA_CALLPHRASE 28 #define MSA_GOTOPHRASE 29 #define MSA_DELAY 30 #define MSA_RESET 31 // 32 - 127 (Reserved) #ifdef _DEBUG_C #pragma mark MSA (Reserved) #endif // 128 - 254 SOUNDCODES #ifdef _DEBUG_C #pragma mark MSA Sound Codes #endif // MSA Sound Codes: Phonemes #define MSAPH_IY 128 #define MSAPH_IH 129 #define MSAPH_EY 130 #define MSAPH_EH 131 #define MSAPH_AY 132 #define MSAPH_AX 133 #define MSAPH_UX 134 #define MSAPH_OH 135 #define MSAPH_AW 136 #define MSAPH_OW 137 #define MSAPH_UH 138 #define MSAPH_UW 139 #define MSAPH_MM 140 #define MSAPH_NE 141 #define MSAPH_NO 142 #define MSAPH_NGE 143 #define MSAPH_NGO 144 #define MSAPH_LE 145 #define MSAPH_LO 146 #define MSAPH_WW 147 #define MSAPH_RR 148 #define MSAPH_IYRR 149 #define MSAPH_EYRR 150 #define MSAPH_AXRR 151 #define MSAPH_AWRR 152 #define MSAPH_OWRR 153 #define MSAPH_EYIY 154 #define MSAPH_OHIY 155 #define MSAPH_OWIY 156 #define MSAPH_OHIH 157 #define MSAPH_IYEH 158 #define MSAPH_EHLL 159 #define MSAPH_IYUW 160 #define MSAPH_AXUW 161 #define MSAPH_IHWW 162 #define MSAPH_AYWW 163 #define MSAPH_OWWW 164 #define MSAPH_JH 165 #define MSAPH_VV 166 #define MSAPH_ZZ 167 #define MSAPH_ZH 168 #define MSAPH_DH 169 #define MSAPH_BE 170 #define MSAPH_BO 171 #define MSAPH_EB 172 #define MSAPH_OB 173 #define MSAPH_DE 174 #define MSAPH_DO 175 #define MSAPH_ED 176 #define MSAPH_OD 177 #define MSAPH_GE 178 #define MSAPH_GO 179 #define MSAPH_EG 180 #define MSAPH_OG 181 #define MSAPH_CH 182 #define MSAPH_HE 183 #define MSAPH_HO 184 #define MSAPH_WH 185 #define MSAPH_FF 186 #define MSAPH_SE 187 #define MSAPH_SO 188 #define MSAPH_SH 189 #define MSAPH_TH 190 #define MSAPH_TT 191 #define MSAPH_TU 192 #define MSAPH_TS 193 #define MSAPH_KE 194 #define MSAPH_KO 195 #define MSAPH_EK 196 #define MSAPH_OK 197 #define MSAPH_PE 198 #define MSAPH_PO 199 // MSA Sound Codes: Robot #define MSAFX_ROBOT_0 200 #define MSAFX_ROBOT_1 201 #define MSAFX_ROBOT_2 202 #define MSAFX_ROBOT_3 203 #define MSAFX_ROBOT_4 204 #define MSAFX_ROBOT_5 205 #define MSAFX_ROBOT_6 206 #define MSAFX_ROBOT_7 207 #define MSAFX_ROBOT_8 208 #define MSAFX_ROBOT_9 209 // MSA Sound Codes: Alarms #define MSAFX_ALARM_0 210 #define MSAFX_ALARM_1 211 #define MSAFX_ALARM_2 212 #define MSAFX_ALARM_3 213 #define MSAFX_ALARM_4 214 #define MSAFX_ALARM_5 215 #define MSAFX_ALARM_6 216 #define MSAFX_ALARM_7 217 #define MSAFX_ALARM_8 218 #define MSAFX_ALARM_9 219 // MSA Sound Codes: Beeps #define MSAFX_BEEP_0 220 #define MSAFX_BEEP_1 221 #define MSAFX_BEEP_2 222 #define MSAFX_BEEP_3 223 #define MSAFX_BEEP_4 224 #define MSAFX_BEEP_5 225 #define MSAFX_BEEP_6 226 #define MSAFX_BEEP_7 227 #define MSAFX_BEEP_8 228 #define MSAFX_BEEP_9 229 // MSA Sound Codes: Biological #define MSAFX_BIO_0 230 #define MSAFX_BIO_1 231 #define MSAFX_BIO_2 232 #define MSAFX_BIO_3 233 #define MSAFX_BIO_4 234 #define MSAFX_BIO_5 235 #define MSAFX_BIO_6 236 #define MSAFX_BIO_7 237 #define MSAFX_BIO_8 238 #define MSAFX_BIO_9 239 // MSA Sound Codes: DTMF #define MSAFX_DTMF_0 240 #define MSAFX_DTMF_1 241 #define MSAFX_DTMF_2 242 #define MSAFX_DTMF_3 243 #define MSAFX_DTMF_4 244 #define MSAFX_DTMF_5 245 #define MSAFX_DTMF_6 246 #define MSAFX_DTMF_7 247 #define MSAFX_DTMF_8 248 #define MSAFX_DTMF_9 249 #define MSAFX_DTMF_S 250 #define MSAFX_DTMF_R 251 // MSA Sound Codes: Misc #define MSAFX_SONAR_PING 252 #define MSAFX_PISTOLSHOT 253 #define MSAFX_WOW 254 // 255: End of Phrase #ifdef _DEBUG_C #pragma mark MSA EOP #endif #define MSA_EOP 255 #endif /* _IIC_SPEAKJETDEFINES_H */
speakjet_definition_list.1150071290.txt.gz · Last modified: 2006/10/15 09:35 (external edit)
