ssm2044_pcb
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
ssm2044_pcb [2009/03/03 19:49]
seppoman
ssm2044_pcb [2016/06/22 00:25]
psykhaze
Line 1: Line 1:
-==== Dual SSM 2044 VCF ====+====== Dual SSM 2044 VCF ======
-[[SSM2044 PCB Bulk Order]]+[[http://​midibox.org/​forums/​index.php?/​topic/​13999-mbhp-eth-mbhp-sdcard-ssm2044-ssm2164-pcb-bulk-order|SSM2044 PCB Bulk Order]]
 +**Warning:​** This is not a suitable project for absolute beginners. The soldering isn't very difficult, but you will need either an AOUT_NG (SMT soldering required), an AOUT module (which needs to be expanded with the bipolar option) or two (!) AOUT_LC modules, or another type of CV source to control this module, in addition to the actual synth (SID/FM) you want to use it with. So a bit of soldering experience and knowledge about the MidiBox platform is definitely recommended. ​
 {{seppoman:​ssm3.jpg?​850x*}} {{seppoman:​ssm3.jpg?​850x*}}
-(click to enlarge)
 This PCB contains two of the famous SSM2044 24dB low pass filters with the necessary circuitry, additional LM13700 based Q linearization circuit and a tiny Omron micro relay for a software controlled (via gate out pins) bypass function. The layout is optimized for use with the [[aout_ng|AOUT_NG]] module, requiring the addition of a bipolar option when used with regular V/Oct sources like the original AOUT module. This PCB contains two of the famous SSM2044 24dB low pass filters with the necessary circuitry, additional LM13700 based Q linearization circuit and a tiny Omron micro relay for a software controlled (via gate out pins) bypass function. The layout is optimized for use with the [[aout_ng|AOUT_NG]] module, requiring the addition of a bipolar option when used with regular V/Oct sources like the original AOUT module.
Line 32: Line 32:
 ==== Parts List ==== ==== Parts List ====
-|Part     ​|Value ​    ​|Reichelt No.   | +|Part           ​|Value ​    ​|Reichelt No.   |
-|C1,​C2 ​   |220 uF    |RAD 220/​25 ​    | +|C1,​C2 ​         |220 uF    |RAD 220/​25 ​    |
-|C3,​C4 ​   |10uF      |RAD 105 10/63  | +|C3,​C4 ​         |10uF      |RAD 105 10/63  |
-|C5-C12 ​  ​|100nF ​    ​|Z5U-2,​5 100N   | +|C5-C12 ​        ​|100nF ​    ​|Z5U-2,​5 100N   |
-|C13,​C14 ​ |100pF ​    ​|NPO-2,​5 100P   | +|C13,​C14 ​       |100pF ​    ​|NPO-2,​5 100P   |
-|C15-C18 ​ |470nF ​    ​|Z5U-5 470N     | +|C15-C18 ​       |470nF ​    ​|Z5U-5 470N     |
-|C19-C24 ​ |10nF      |STYROFLEX 10N  | +|C19-C24 ​       |10nF      |STYROFLEX 10N  |
-|C25,​C26 ​ |820pF ​    ​|STYROFLEX 820P | +|C25,​C26 ​       |820pF ​    ​|STYROFLEX 820P |
-|D1       ​|1N4148 ​   |1N 4148        | +|D1             ​|1N4148 ​   |1N 4148        |
-|IC1,​IC2 ​ |SSM2044 ​  ​| ​              | +|IC1,​IC2 ​       |SSM2044 ​  ​| ​              |
-|IC3      |LM13700 ​  |LM 13700 DIL   | +|IC3            |LM13700 ​  |LM 13700 DIL   |
-|IC4      |TL072P ​   |TL 072 DIP     | +|IC4            |TL072P ​   |TL 072 DIP     |
-|K1       ​|G6K-2P ​   |G6K-2P 12V     | +|K1             ​|G6K-2P ​   |G6K-2P 12V     |
-|P1,​P2 ​   |10k       ​|64W-10K ​       | +|P1,​P2 ​         |10k       ​|64W-10K ​       |
-|P3,​P4 ​   |500       ​|64W-500 ​       | +|P3,​P4 ​         |500       ​|64W-500 ​       |
-|R1-R6 ​   |220       ​|METALL 220     | +|R1-R6 ​         |220       ​|METALL 220     |
-|R7-R13 ​  ​|1k        |METALL 1,00K   | +|R7-R13 ​        ​|1k        |METALL 1,00K   |
-|R14,​R15 ​ |100       ​|METALL 100     | +|R14,​R15 ​       |100       ​|METALL 100     |
-|R16,​R17 ​ |10k       ​|METALL 10,0K   | +|R16,​R17 ​       |10k       ​|METALL 10,0K   |
-|R18,​R19 ​ |24k       ​|METALL 24,0K   | +|R18,​R19 ​       |24k       ​|METALL 24,0K   |
-|R20,21   |47k       ​|METALL 47,0K   | +|R20,R21,R24-R27|47k       ​|METALL 47,0K   |
-|R22,​R23 ​ |27k       ​|METALL 27,0K   | +|R22,​R23 ​       |27k       ​|METALL 27,0K   |
-|R24-R27 ​ |47k       ​|METALL 47,0K   | +|R28,​R29 ​       |100k      |METALL 100K    |
-|R28,​R29 ​ |100k      |METALL 100K    | +|T1             ​|BC547 ​    |BC 547C        |
-|T1       ​|BC547 ​    |BC 547C        |+
 +Total cost of all parts (without SSMs): about 11.50 Euros
-Total cost of all parts (without SSMs)about 13 Euros+nILS did a Reichelt [[https://​secure.reichelt.de/?;​ACTION=20;​LA=5010;​AWKID=137885;​PROVID=2084|Reichelt public shopping cart]], thanks for that :)
 ==== Design ==== ==== Design ====
ssm2044_pcb.txt · Last modified: 2016/06/22 00:25 by psykhaze
