ssm2044_pcb_bulk_order [2009/10/05 19:12] ampersand |
ssm2044_pcb_bulk_order [2010/03/11 08:38] seppoman |
Line 7: | Line 7: | ||
**Warning:** This is not a suitable project for absolute beginners. The soldering isn't very difficult, but you will need either an AOUT_NG (SMT soldering required), an AOUT module (which needs to be expanded with the bipolar option) or two (!) AOUT_LC modules, or another type of CV source to control this module, in addition to the actual synth (SID/FM) you want to use it with. So a bit of soldering experience and knowledge about the MidiBox platform is definitely recommended. | **Warning:** This is not a suitable project for absolute beginners. The soldering isn't very difficult, but you will need either an AOUT_NG (SMT soldering required), an AOUT module (which needs to be expanded with the bipolar option) or two (!) AOUT_LC modules, or another type of CV source to control this module, in addition to the actual synth (SID/FM) you want to use it with. So a bit of soldering experience and knowledge about the MidiBox platform is definitely recommended. | ||
- | **The original bulk order is closed.** I might start another bulk order this year if there's enough demand. You can express your interest in getting PCBs by adding yourself to the list below. **Note that I don't promise to start this bulk order at any specific time of year, so please don't send me PMs about that - I'll collect orders from everyone on the list and will announce the bulk order on the forum as soon as something is happening!** | + | [[http://midibox.org/forums/index.php?/topic/13999-mbhp-eth-mbhp-sdcard-ssm2044-ssm2164-pcb-bulk-order|Current Bulk Order]] |
- | |**Username**|**Number of PCBs**| | + | |
- | |rosch|10| | + | |
- | |modularman|4| | + | |
- | |henrikgo|1| | + | |
- | |kroutshev|2| | + | |
- | |Strophlex|5| | + | |
- | |booster|2| | + | |
- | |jooks|2| | + | |
- | |kok6|2| | + | |
- | |iorobyy|2| | + | |
- | |lead bromide|2| | + | |
- | |SexyBeast|4| | + | |
- | |stevenclements|2| | + | |
- | |Morten|2| | + | |
- | |jovius|2| | + | |
- | |unrise_lyrical|4| | + | |
- | |Tamiflu|4| | + | |
- | |fussylizard|8| | + | |
- | |LeonT|2| | + | |
- | |ampersand|2| | + |
