ssm2164_pcb [2010/07/09 14:43] seppoman |
ssm2164_pcb [2018/04/22 12:14] phatline [Parts List] |
Line 9: | Line 9: | ||
|C7-C12 |100nF |Z5U-2,5 100N | | |C7-C12 |100nF |Z5U-2,5 100N | | ||
|C13-16 |100pF |NPO-2,5 100P | | |C13-16 |100pF |NPO-2,5 100P | | ||
- | |C17-C20 |470nF |Z5U-5 470N | | + | |C17-C20 |470nF |Z5U-5 470N (*2)| |
|IC1 |SSM2164PZ |(*) | | |IC1 |SSM2164PZ |(*) | | ||
|IC2,IC3 |TL074 |TL 074 DIL | | |IC2,IC3 |TL074 |TL 074 DIL | | ||
Line 19: | Line 19: | ||
(IC sockets, pin headers, flat ribbon cable etc are omitted) | (IC sockets, pin headers, flat ribbon cable etc are omitted) | ||
+ | [[http://www.reichelt.de/?ACTION=20;AWKID=260750;PROVID=2084|Reichelt Public Shopping Cart]] | ||
=== Where to get the SSM2164 === | === Where to get the SSM2164 === | ||
- | (*) There are quite a few places where you can buy the SSM2164, e.g. Farnell or Digikey usually have them on stock. Feel free to add your finds to this section :) | + | (*) There are quite a few places where you can buy the SSM2164. Feel free to add your finds to this section :) |
+ | ^Shop ^Order Code ^Price ^Date Price Checked ^ | ||
+ | |**Europe:** |||| | ||
+ | |[[http://de.farnell.com|Farnell]] |1438744 |6.33 EUR + VAT | //(2010/07/14)// | | ||
+ | |[[http://de.rsonline.com|RS]] |427-250 |6.33 EUR + VAT | //(2010/07/14)// | | ||
+ | |**USA:** |||| | ||
+ | |[[http://www.digikey.com|Digikey]] |SSM2164PZ-ND |6.00 USD | //(2010/07/14)// | | ||
+ | |[[http://www.newark.com|Newark]] |19M9009 |6.06 USD | //(2010/07/14// | | ||
+ | Note that Farnell only delivers to professional customers and university members. | ||
=== Value of C17..C20 === | === Value of C17..C20 === | ||
- | These capacitors are part of a low pass filter that smoothes out noise/DAC steps etc from the CV input signal. There's a tradeoff between best cancellation of any zipper/background noise and a very snappy VCA on the other side. The value of 470nF stated in the parts list above is more on the "Silence" side of things. If you prefer a faster response of the VCA in return for some noise in certain situations, you can try lower values in this place. e.g. 220nF is a usable compromise, but you can go lower to 100nF, 10nF or even leave out the capacitor altogether. I suggest you might try out what suits you best with one single channel before stuffing all four caps. | + | (*2) These capacitors are part of a low pass filter that smoothes out noise/DAC steps etc from the CV input signal. There's a tradeoff between best cancellation of any zipper/background noise and a very snappy VCA on the other side. The value of 470nF stated in the parts list above is more on the "Silence" side of things. If you prefer a faster response of the VCA in return for some noise in certain situations, you can try lower values in this place. e.g. 220nF is a usable compromise, but you can go lower to 100nF, 10nF or even leave out the capacitor altogether. I suggest you might try out what suits you best with one single channel before stuffing all four caps. |
+ | === setup and interconnect the module - getting startet === | ||
+ | [[ssm2164_getting_started]] |
