stm32f4_module [2016/08/03 17:37] psykhaze [Known Issues] |
stm32f4_module [2016/08/03 17:48] psykhaze [Features] |
Line 15: | Line 15: | ||
* Very useful integrated peripherals for MIDI and Synthesizer applications, such as **UART, SPI, I2C, USB, CAN, Timers, ADC, DAC** | * Very useful integrated peripherals for MIDI and Synthesizer applications, such as **UART, SPI, I2C, USB, CAN, Timers, ADC, DAC** | ||
* The USB OTG (Micro-USB) socket supports **MIDI Host**, which means that it's possible to connect a USB MIDI Keyboard or Synth | * The USB OTG (Micro-USB) socket supports **MIDI Host**, which means that it's possible to connect a USB MIDI Keyboard or Synth | ||
- | * The on-board Audio DAC predestinates this module for synthesizer projects - it could even be used standalone without the MBHP_CORE_STM32F4 breakout board for this purpose. | + | * **The on-board Audio DAC predestinates this module for synthesizer projects** - it could even be used standalone without the MBHP_CORE_STM32F4 breakout board for this purpose. |
* in distance to STM32F103RE, **CAN and USB can be used in parallel** | * in distance to STM32F103RE, **CAN and USB can be used in parallel** | ||
- | * It's easy to interface external components like SD Cards and MBHP_ETH | + | * **It's easy to interface external components like SD Cards and MBHP_ETH** |
* STM32F4xx is supplied at 3V, but **5V tolerant inputs allow to access all existing MBHP modules without additional hardware**. | * STM32F4xx is supplied at 3V, but **5V tolerant inputs allow to access all existing MBHP modules without additional hardware**. | ||
* **Performance boost by using the DMA** for background operations, such as scanning DIN/DOUT modules, analog inputs but also I2S transfers (Audio Output) w/o loading the CPU | * **Performance boost by using the DMA** for background operations, such as scanning DIN/DOUT modules, analog inputs but also I2S transfers (Audio Output) w/o loading the CPU | ||
Line 33: | Line 33: | ||
* **No PHY for the second USB peripheral** - would be nice to have, e.g. to support USB MIDI device and host (e.g. for the connection of a USB MIDI Keyboard), USB Memory Sticks or even a USB harddisk in parallel. | * **No PHY for the second USB peripheral** - would be nice to have, e.g. to support USB MIDI device and host (e.g. for the connection of a USB MIDI Keyboard), USB Memory Sticks or even a USB harddisk in parallel. | ||
- | ===== Parts List ===== | + | ===== Parts List / Schematic===== |
See [[stm32f4_core_board_parts_list|Core32 Parts List]] | See [[stm32f4_core_board_parts_list|Core32 Parts List]] | ||
+ | * {{http://ucapps.de/mbhp/mbhp_core_stm32f4.pdf|Core32 Schematic}} <sup>UCapps</sup> | ||
===== Inputs/Outputs Ports ===== | ===== Inputs/Outputs Ports ===== | ||
Line 43: | Line 45: | ||
===== Buy Places ===== | ===== Buy Places ===== | ||
+ | * [[http://www.digikey.com/product-detail/en/stmicroelectronics/STM32F407G-DISC1/497-16287-ND/5824404|Digikey]] | ||
+ | * [[http://www.mouser.fr/ProductDetail/STMicroelectronics/STM32F4DISCOVERY/?qs=J2qbEwLrpCGdWLY96ibNeQ%3d%3d|Mouser]] | ||
+ | * [[http://export.farnell.com/stmicroelectronics/stm32f407g-disc1/dev-board-foundation-line-mcu/dp/2506840?selectedCategoryId=&exaMfpn=true&categoryId=&searchRef=SearchLookAhead&searchView=table&iscrfnonsku=false|Farnell]] | ||
+ | * [[https://www.amazon.com/STM32F4DISCOVERY-ST-STM32F407-Evaluation-Development/dp/B00CW9AKDY|Amazon]] | ||
+ | * [[http://www.ebay.com/sch/i.html?_from=R40&_trksid=p2047675.m570.l1313.TR2.TRC0.A0.H0.XSTM32F407.TRS0&_nkw=STM32F407&_sacat=0|Ebay]] | ||
+ | * [[http://www.watterott.com/de/STM32F4Discovery|Watterot DE]] |
