stm32f4_module [2016/08/03 17:48] psykhaze [Parts List / SChematic] |
stm32f4_module [2016/08/03 17:48] psykhaze [Features] |
Line 15: | Line 15: | ||
* Very useful integrated peripherals for MIDI and Synthesizer applications, such as **UART, SPI, I2C, USB, CAN, Timers, ADC, DAC** | * Very useful integrated peripherals for MIDI and Synthesizer applications, such as **UART, SPI, I2C, USB, CAN, Timers, ADC, DAC** | ||
* The USB OTG (Micro-USB) socket supports **MIDI Host**, which means that it's possible to connect a USB MIDI Keyboard or Synth | * The USB OTG (Micro-USB) socket supports **MIDI Host**, which means that it's possible to connect a USB MIDI Keyboard or Synth | ||
- | * The on-board Audio DAC predestinates this module for synthesizer projects - it could even be used standalone without the MBHP_CORE_STM32F4 breakout board for this purpose. | + | * **The on-board Audio DAC predestinates this module for synthesizer projects** - it could even be used standalone without the MBHP_CORE_STM32F4 breakout board for this purpose. |
* in distance to STM32F103RE, **CAN and USB can be used in parallel** | * in distance to STM32F103RE, **CAN and USB can be used in parallel** | ||
- | * It's easy to interface external components like SD Cards and MBHP_ETH | + | * **It's easy to interface external components like SD Cards and MBHP_ETH** |
* STM32F4xx is supplied at 3V, but **5V tolerant inputs allow to access all existing MBHP modules without additional hardware**. | * STM32F4xx is supplied at 3V, but **5V tolerant inputs allow to access all existing MBHP modules without additional hardware**. | ||
* **Performance boost by using the DMA** for background operations, such as scanning DIN/DOUT modules, analog inputs but also I2S transfers (Audio Output) w/o loading the CPU | * **Performance boost by using the DMA** for background operations, such as scanning DIN/DOUT modules, analog inputs but also I2S transfers (Audio Output) w/o loading the CPU |
