Developing MIOS Applications with Code::Blocks
GNU PIC Utilities (GPUtils)
Install the complete application using the 'Complete' option.
When the installer asks you, click 'Yes' to add the installation directory to the PATH environment variable.
ActiveState ActivePerl
Install using defaults, I recommend changing the path to c:\program files\activestate\perl
If you are prompted to restart your computer, then do so.
Small Device C Compiler (SDCC)
Environment Variables
Normally, the necessary directories are added to you PATH environment variable during the above installations. Sometimes, they aren't. Here's how to check it:
Minimise any open windows so that you can see the desktop.
Right-click on 'My Computer', select 'Properties'.
Click on the 'Advanced' tab, then click 'Environment Variables'
Under either User or System variables, select the variable 'PATH' and click 'Edit'
Add these entries if they don't exist:
;C:\Program Files\ActiveState\PERL\bin\
;C:\Program Files\SDCC\bin
;C:\Program Files\gputils\bin
Sun Java J2SE
Code::Blocks IDE
Installer
Upgrade
For our purposes, CodeBlocks should be updated to the latest nightly build. Required features are unavailable in RC2 which has been installed above.
Download a
newer wxwidgets dll and extract to the CodeBlocks Program Directory, for example C:\Program Files\CodeBlocks\
Get link for Nightly Build from the
CB Forum
Delete share\ dir, for example C:\Program Files\CodeBlocks\share\*.*
Unzip downloaded file to Program Directory, for example C:\Program Files\CodeBlocks\, and overwrite where prompted.
Start Code:Blocks, it will detect and configure installed compilers. Accept defaults.
Project Setup
A C::B Project can be setup from either an existing MIOS C Application or the SDCC_Skeleton App as follows. You should have your application/skeleton in a dedicated folder.
If you are creating a new application, you can simply download the MIOS SDCC Skeleton Application Template, extract it to your template directory, and start with that, and none of the below steps are necessary.
Create Empty Project
Start Code::Blocks
Open a new project ('File… New Project')
Tick the checkbox 'Show File-based Templates'
Click 'SDCC Application' from the list. You may need to scroll down to see it. If it is not there, ensure you have performed the previous step
In the box labelled 'Project Path and Name', browse to the directory containing your MIOS Application or Skeleton, and add the name of your Project
In the box labelled 'Options', tick the box labelled 'Do not create any files'
Click 'OK'
Click 'Yes' on dialog(s) stating that the directory already exists
Add Application files to project
Select 'Project… Properties', Select the 'Targets' tab, Click 'Add'
Name the target 'MBHP', and Click OK
In the box labelled 'Selected build target options', select 'Commands Only' from the drop-down list labelled 'Type'
In the box labelled 'Selected build target files', Tick ONLY 'main.c'
Returning to 'Project… Properties', 'Targets' tab, Click 'Add'
Name the target '
MB-ACSim', and Click OK
In the box labelled 'Selected build target options', select 'Console Application' from the drop-down list labelled 'Type'
In the box labelled 'Selected build target files', Tick ONLY 'debug.c'
Click 'OK' to close project properties
Select 'Project… Properties', Select the 'Targets' tab (Yes, again. It is necessary to apply the previous settings first)
select target 'Default', click 'Delete', Click 'Yes' to confirm deletion
select target 'MBHP', click 'Build Options'
In the box labelled 'Selected Compiler' Select 'SDCC Compiler' from the dropdown list, Click 'OK' (until this point both targets will be using C::B's default of GCC)
In the box labelled 'Selected build target files', select file 'main.c' and then click 'Selected File Properties'
Select the 'Advanced' tab, in the box labelled 'Custom Build', Select 'SDCC Compiler' from the dropdown list labelled 'For this compiler'
Tick 'Use Custom Command to build this file'
Type into the textbox “make.bat”
Click OK
Click OK
MIOS-Specific SDCC Libraries
TK says:
If multiplications, divisions, pointer operations, etc. are used in the .c code, the linker may fail due to missing functions, which are part of the “libsdcc.lib” library. The common library for pic16 derivatives is not compatible to MIOS, therefore I've created a special one. Click here for more information
Create a 'lib' directory within the root directory of your project
Copy the 'libsdcc.lib' file from the above zip file into this directory
Open the “project.lkr” file of your project and add following line below the “LIBPATH” entry:
FILES lib/libsdcc.lib
AC-Sim Setup
