stuartm_stukontrol
Differences
Link to this comparison view
Both sides previous revision Previous revision
Last revision Both sides next revision
stuartm_stukontrol [2010/07/23 09:43]
stuartm
stuartm_stukontrol [2010/07/23 09:45]
stuartm
Line 55: Line 55:
 For a breadboard test, i connected two pots to the AINX and the module to the core, grounded the remaining inputs, started MIDI-OX on the laptop, powered up the core and WEEEEEE! It worked! For a breadboard test, i connected two pots to the AINX and the module to the core, grounded the remaining inputs, started MIDI-OX on the laptop, powered up the core and WEEEEEE! It worked!
 I fired up Ableton Live and created a short sequence with impOSCar and routed the two pots to cutoff and resonance. I fired up Ableton Live and created a short sequence with impOSCar and routed the two pots to cutoff and resonance.
-It all worked well and without any signal hazzles, so I quickly decided to record a short video [HERE].+It all worked well and without any signal hazzles, so I quickly decided to record a short video
 +http://​vimeo.com/​7903764
 In parallel, I had finished the panel design and ordered it from Schaeffer. In parallel, I had finished the panel design and ordered it from Schaeffer.
stuartm_stukontrol.txt · Last modified: 2016/07/03 13:05 by psykhaze
