switch [2016/06/15 12:51] psykhaze [Switch] |
switch [2016/07/10 15:04] psykhaze [Matrix Design] |
Line 8: | Line 8: | ||
A switch that has just two positions is called a toggle switch.A "click switch" is called SPST switch. | A switch that has just two positions is called a toggle switch.A "click switch" is called SPST switch. | ||
+ | {{ ::neonking:switches.jpg?direct |}} | ||
===== Some Refs? ===== | ===== Some Refs? ===== | ||
Line 14: | Line 16: | ||
You should have a look to <wrap info>[[parts_faq#what_kind_of_switches_do_i_need|Switch Choosing Guide]]</wrap> | You should have a look to <wrap info>[[parts_faq#what_kind_of_switches_do_i_need|Switch Choosing Guide]]</wrap> | ||
+ | ===== DIN Connection ===== | ||
+ | {{ :neonking:encoder-switch-din.jpg?direct&600 |}} | ||
+ | ==== Matrix Design ==== | ||
+ | {{ :neonking:switchmatrix.jpg?direct&800 |}} |
