tpd_pcb [2020/02/16 16:18] ilmenator [Where to buy?] |
tpd_pcb [2021/03/09 15:04] ilmenator [Where to buy?] |
Line 25: | Line 25: | ||
==== Where to buy? ==== | ==== Where to buy? ==== | ||
- | If you are interested in building this, send a personal message (PM) to user //ilmenator// over at the [[http://midibox.org/forums/|MIDIbox forum]] (you have to register to be able to send PM). As of February 2020, I have PCBs (both the original TPD as well as the Euro TPD, see below) available for 10€ each, as well as a small number of kits for those having difficulties sourcing the parts themselves. Kit price for all you need to build this, i.e. PCB including every part on the BOM below, is 48€. | + | If you are interested in building this, send a personal message (PM) to user //ilmenator// over at the [[http://midibox.org/forums/|MIDIbox forum]] (you have to register to be able to send PM). As of March 2021, I have PCBs (both the original TPD as well as the Euro TPD, see below) available for 10€ each, as well as a small number of kits for those having difficulties sourcing the parts themselves. Kit price for all you need to build this, i.e. PCB including every part on the BOM below, is 48€. |
===== Euro TPD format ===== | ===== Euro TPD format ===== | ||
Line 57: | Line 57: | ||
There is a [[http://midibox.org/forums/topic/20807-tpd-testing-and-configuration-questions/|thread]] over on the MIDIbox Forum discussing TPD testing and configuration. | There is a [[http://midibox.org/forums/topic/20807-tpd-testing-and-configuration-questions/|thread]] over on the MIDIbox Forum discussing TPD testing and configuration. | ||
+ | Or you use this Test-app {{:phatline:tpd-test.zip|}} - see the forum article above. | ||
The most exotic component on this board is the red/green double color dot matrix module. As the LEDs are controlled via a matrix approach, it does not really matter whether you choose common cathode or common anode modules - both will work, you'll just have to specify that in the config file. I bought mine on ebay, and they are common anode types (although they were sold to me as common cathode types!). Make sure that the pinout follows this {{:home:users:ilmenator:ysm-1288cr3g2c.pdf|duo LED matrix datasheet}}! | The most exotic component on this board is the red/green double color dot matrix module. As the LEDs are controlled via a matrix approach, it does not really matter whether you choose common cathode or common anode modules - both will work, you'll just have to specify that in the config file. I bought mine on ebay, and they are common anode types (although they were sold to me as common cathode types!). Make sure that the pinout follows this {{:home:users:ilmenator:ysm-1288cr3g2c.pdf|duo LED matrix datasheet}}! |
