triggermatrix4 [2021/07/30 23:16] phatline |
triggermatrix4 [2021/07/31 13:05] phatline |
Line 1: | Line 1: | ||
====== TriggerMatrix V4 ====== | ====== TriggerMatrix V4 ====== | ||
- | {{:phatline:TM4.jpg?700|}}\\ | + | |
- | \\ | + | **REAL:**\\ |
- | **Planed in 3D:**\\ | + | {{:phatline:tm4-perspektive-l.hd-.jpg?700|}}\\ |
+ | **CAD-Design:**\\ | ||
{{:phatline:TM4-Render-black.jpg?700|}}\\ | {{:phatline:TM4-Render-black.jpg?700|}}\\ | ||
Line 9: | Line 11: | ||
- | ===== CODE, FIRMWARE ===== | + | ===== CODE, FIRMWARE ===== |
- | **1. Upload MIOS Bootloader**\\ | + | **Install [[http://www.ucapps.de/mios_studio.html|MIOS Studio]], connect TM4 via USB, and Start the STUDIO**\\ |
- | **2. type following commands into the MIOS-TERMINAL:**\\ | + | \\ |
+ | **1. Upload [[http://www.ucapps.de/mios32/mios32_bootloader_v1_018.zipm|MIOS BOOTLOADER]]**\\ | ||
+ | **2. (only needet for Virgin Machines) type following commands into the MIOS-TERMINAL:**\\ | ||
* set lcd_type GLCD_SSD1306_ROTATED\\ | * set lcd_type GLCD_SSD1306_ROTATED\\ | ||
* set lcd_num_x 9\\ | * set lcd_num_x 9\\ | ||
Line 18: | Line 22: | ||
* set lcd_height 64\\ | * set lcd_height 64\\ | ||
* store\\ | * store\\ | ||
- | **3. Upload the Triggermatrix Code:**\\ | + | **3. (for Version Updates) Unzip {{:phatline:TM4.zip|the TM4-Firmware}}, and Upload the TM4.hex**\\ |
- | {{:phatline:tm_V3.zip|the Code}} FIXME upload TM4 Code\\ | + | **4. Unconnect USB & Connect the USB again --- finished.**\\ |
+ | **5. If the Machine is not detected by mios studio, and you already checked the usb-connections, the device or the code is broken, for that on the backside of TM4 is a switch, please set it to "bLOAD", now you can upload new & unbroken codes, dont forget to set it to "normal" back again - after upload new code - else the APP will not boot...**\\ | ||
===== BUILD ===== | ===== BUILD ===== | ||
Line 66: | Line 71: | ||
{{:phatline:TM4-Labeled.jpg?400|}}\\ | {{:phatline:TM4-Labeled.jpg?400|}}\\ | ||
**Wires:**\\ | **Wires:**\\ | ||
- | {{:phatline:TM4-Wire-Fader-Detail.jpg?400|}}\ | + | {{:phatline:TM4-Wire-Fader-Detail.jpg?400|}} |
- | {{:phatline:TM4-Wires.jpg?400|}}\\ | + | {{:phatline:TM4-Wires.jpg?400|}} |
+ | {{:phatline:TM4-Wired.jpg?400|}} | ||
**Wood-Elements:**\\ | **Wood-Elements:**\\ | ||
Line 73: | Line 79: | ||
{{:phatline:TM4-Woods-measures.jpg?700|}}\\ | {{:phatline:TM4-Woods-measures.jpg?700|}}\\ | ||
{{:phatline:TM4-Woods-paint.jpg?700|}}\\ | {{:phatline:TM4-Woods-paint.jpg?700|}}\\ | ||
+ | {{:phatline:TM4-Wood-Mount.jpg?700|}}\\ | ||
+ | **Screws:**\\ | ||
+ | {{:phatline:TM4-PCB-Spacer.jpg?700|}}\\ | ||
+ | {{:phatline:TM4-M2-Nuts.jpg?700|}}\\ | ||
**DIY-Back-Panel:**\\ | **DIY-Back-Panel:**\\ | ||
Line 114: | Line 126: | ||
* Free programmable Swing to each Step, with 2 different swing Length-sets, which are controlled live with encoder\\ | * Free programmable Swing to each Step, with 2 different swing Length-sets, which are controlled live with encoder\\ | ||
* copy, paste, erase of pages\\ | * copy, paste, erase of pages\\ | ||
- | * copy, paste, erase of rows\\E | + | * copy, paste, erase of rows\\ |
* fixed forward play direction\\ | * fixed forward play direction\\ | ||
