triggermatrix4 [2021/07/31 12:53] phatline [CODE, FIRMWARE] |
triggermatrix4 [2021/10/21 13:39] phatline |
Line 1: | Line 1: | ||
====== TriggerMatrix V4 ====== | ====== TriggerMatrix V4 ====== | ||
- | {{:phatline:TM4.jpg?700|}}\\ | + | |
- | **Planed in 3D:**\\ | + | **REAL:**\\ |
+ | {{:phatline:tm4-perspektive-l.hd-.jpg?700|}}\\ | ||
+ | **CAD-Design:**\\ | ||
{{:phatline:TM4-Render-black.jpg?700|}}\\ | {{:phatline:TM4-Render-black.jpg?700|}}\\ | ||
Line 10: | Line 13: | ||
===== CODE, FIRMWARE ===== | ===== CODE, FIRMWARE ===== | ||
**Install [[http://www.ucapps.de/mios_studio.html|MIOS Studio]], connect TM4 via USB, and Start the STUDIO**\\ | **Install [[http://www.ucapps.de/mios_studio.html|MIOS Studio]], connect TM4 via USB, and Start the STUDIO**\\ | ||
**1. Upload [[http://www.ucapps.de/mios32/mios32_bootloader_v1_018.zipm|MIOS BOOTLOADER]]**\\ | **1. Upload [[http://www.ucapps.de/mios32/mios32_bootloader_v1_018.zipm|MIOS BOOTLOADER]]**\\ | ||
**2. (only needet for Virgin Machines) type following commands into the MIOS-TERMINAL:**\\ | **2. (only needet for Virgin Machines) type following commands into the MIOS-TERMINAL:**\\ | ||
Line 18: | Line 22: | ||
* set lcd_height 64\\ | * set lcd_height 64\\ | ||
* store\\ | * store\\ | ||
- | **3. (for Version Updates) Upload the Triggermatrix Code:**\\ | + | **3. (for Version Updates) Unzip {{:phatline:TM4.zip|the TM4-Firmware}}, and Upload the TM4.hex**\\ |
- | {{:phatline:tm_V3.zip|the Code}} FIXME upload TM4 Code\\ | + | **4. Unconnect USB & Connect the USB again --- finished.**\\ |
+ | **5. If the Machine is not detected by mios studio, and you already checked the usb-connections, the device or the code is broken, for that on the backside of TM4 is a switch, please set it to "bLOAD", now you can upload new & unbroken codes, dont forget to set it to "normal" back again - after upload new code - else the APP will not boot...**\\ | ||
===== BUILD ===== | ===== BUILD ===== | ||
Line 46: | Line 51: | ||
* 3mm Alu Plates for Ground and Backpanel (you cut and drill it by your own) | * 3mm Alu Plates for Ground and Backpanel (you cut and drill it by your own) | ||
* 3mm Alu Frontpanel, CNC-machined (See DXF-File for more info) | * 3mm Alu Frontpanel, CNC-machined (See DXF-File for more info) | ||
+ | ===== MODs ===== | ||
+ | ==== Stable USB-Type-B - Mod ==== | ||
+ | {{:phatline:TM4-USB-TYPE-B-MOD.jpg?400|}}\ | ||
====Pictured Doku==== | ====Pictured Doku==== |
