Next revision | Previous revision | ||
wcore_line-transmit [2017/09/11 22:07] latigid_on created |
wcore_line-transmit [2018/12/18 09:39] latigid_on [BOM v1.0] |
Line 7: | Line 7: | ||
[[http://www.ucapps.de/mbhp/mbhp_line_driver_transmitter.pdf|MBHP Transmitter]]. | [[http://www.ucapps.de/mbhp/mbhp_line_driver_transmitter.pdf|MBHP Transmitter]]. | ||
- | The two obvious differences are the J3 jumper (disconnects +5V from being sent) and the addition of a 100mil header. This way a DB-25 connector (or something else?) with ribbon cable mounting could be mounted off-board and connected to the line driver with an IDC. | + | The two obvious differences are the J3 jumper (disconnects +5V from being sent) and the addition of a 100mil header. This way a DB-25 (or something else?) with ribbon cable mounting could be positioned off-board and wired to the line driver with an IDC. |
Line 13: | Line 13: | ||
===== BOM v1.0 ===== | ===== BOM v1.0 ===== | ||
+ | **Please find the current BOM on [[http://midiphy.com]]. The table below is depreciated and will not be updated.** | ||
^Type ^Qty ^Value ^Package ^Parts^Mouser^Reichelt^Conrad^Other^Notes^ | ^Type ^Qty ^Value ^Package ^Parts^Mouser^Reichelt^Conrad^Other^Notes^ | ||
Line 29: | Line 31: | ||
| |0 (1) |2*13 |male | | | | | | | | | |0 (1) |2*13 |male | | | | | | | | ||
^Sockets^^^^^^^^^^ | ^Sockets^^^^^^^^^^ | ||
- | | |1 (0) |DB-25 |female | |806-KCDX-5S-S2 | | | | | | + | | |1 (0) |DB-25 |female | | | | | | | |
^Hardware^^^^^^^^^^ | ^Hardware^^^^^^^^^^ | ||
| |0 (3) |M3 spacer | | | | | | |optional, suggest to panel mount | | | |0 (3) |M3 spacer | | | | | | |optional, suggest to panel mount | |
