wcoref4_pcb
Differences
Link to this comparison view
Both sides previous revision Previous revision
Next revision
Previous revision
Last revision Both sides next revision
wcoref4_pcb [2017/10/04 22:01]
latigid_on
wcoref4_pcb [2018/08/20 21:29]
latigid_on
Line 32: Line 32:
 ^Resistors^^^^^^^^^^  ^Resistors^^^^^^^^^^
 |         ​|1 ​   |330R 5%   ​|THT ​        ​|R102 ​        ​| ​     |        |      |     | | |         ​|1 ​   |330R 5%   ​|THT ​        ​|R102 ​        ​| ​     |        |      |     | |
-|         |   ​|1k ​  ​5% ​  ​|1206 ​       |R7B1-4 ​      |      |        |      |     | |+|         |1    |560R 5%   ​|THT ​        ​|R33D ​       |      |        |      |     | |
 +|         ​|3 ​   ​|1k ​  ​5% ​  ​|1206 ​       |R33A,​B,​C ​     ​|      |        |      |     | |
 |         ​|2 ​   |1k   ​5% ​  ​|THT ​        |R11, R13     ​| ​     |        |      |     | | |         ​|2 ​   |1k   ​5% ​  ​|THT ​        |R11, R13     ​| ​     |        |      |     | |
 |         ​|2 ​   |2k2 5%   ​|THT ​        |R7A, R8A     ​| ​     |        |      |     | | |         ​|2 ​   |2k2 5%   ​|THT ​        |R7A, R8A     ​| ​     |        |      |     | |
Line 63: Line 64:
 ===== Versions ===== ===== Versions =====
 +v1.2: general release. Changes:
 +  * The [[wcore_usb|USB]] board is now combined with the wCore. It can be used as is or broken apart and the USB reconnected with wires, a 2.54mm header or a 10-pin Micro-MaTch connector.
 +  * Resistors R7B1-4 were renamed properly to R33A-D. R33**D** should have a different value (560~820R) than R33A/B/C (1k). Using longer cables on J15A/B and a smaller resistance for R33D could lead to displays not initialising properly. ​
 +  * There is a circular silkscreen mark that aligns with the same mark on the Waveshare breakout.
 v1.0: first release. v1.0: first release.
Line 97: Line 105:
     * The 407v board should not protrude past the edge of the PCB.     * The 407v board should not protrude past the edge of the PCB.
   * Remove the OTG jumpers "​FLG,"​ "​VBUS"​ and "PWR OUT." USB won't work properly with these closed.   * Remove the OTG jumpers "​FLG,"​ "​VBUS"​ and "PWR OUT." USB won't work properly with these closed.
-  * I believe that the correct state of the BOOT CONFIG switch should be set to "SYSTEM"+  * I believe that the correct state of the BOOT CONFIG switch should be set to "FLASH"
   * There'​s another switch to select the +5V power. It should be set to "​USB"​ when flashing the board using the USB mini connector as a power source, but for our purposes set it to "PWR 5V".   * There'​s another switch to select the +5V power. It should be set to "​USB"​ when flashing the board using the USB mini connector as a power source, but for our purposes set it to "PWR 5V".
wcoref4_pcb.txt · Last modified: 2018/12/18 09:36 by latigid_on
