Writing /var/www/midibox.org/dokuwiki/data/meta/wiki/welcome.meta failed
Unable to save metadata file. Hint: disk full; file permissions; safe_mode setting.
wiki:welcome
Welcome to your new DokuWiki
Congratulations, your wiki is now up and running. Here are a few more tips to get you started.
Enjoy your work with DokuWiki,
– the developers
Create your first pages
Your wiki needs to have a start page. As long as it doesn't exist, this link will be red: start.
Go on, follow that link and create the page. If you need help with using the syntax you can always refer to the syntax page.
You might also want to use a sidebar. To create it, just edit the sidebar page. Everything in that page will be shown in a margin column on the side. Read our FAQ on sidebars to learn more.
Please be aware that not all templates support sidebars.
Customize your Wiki
Once you're comfortable with creating and editing pages you might want to have a look at the configuration settings (be sure to login as superuser first).
You may also want to see what plugins and templates are available at DokuWiki.org to extend the functionality and looks of your DokuWiki installation.
Join the Community
DokuWiki is an Open Source project that thrives through user contributions. A good way to stay informed on what's going on and to get useful tips in using DokuWiki is subscribing to the newsletter.
The DokuWiki User Forum is an excellent way to get in contact with other DokuWiki users and is just one of the many ways to get support.
Of course we'd be more than happy to have you getting involved with DokuWiki.
wiki/welcome.txt · Last modified: 2017/08/23 18:21 (external edit)
