wikify:template:project
STILL INCOMPLETE
Intro
All about it, what it does and blah
Features
List 'em
Skills / Equipment Required
Harware
What modules do I need?
Adjust List as required:
- + Any custom modules (create link in your projects name space or ':mbhp:module:<you_module>“
List of parts
list of pots, buttons, faders and blah - suggestions on good parts and where to buy them + how to hool them up - links
Connections
Connection diagrams - links if needed (create in you projects namespace
Enclosure / Case
Enclosure ideas - link to case construction tips? / provide space to encourage other users to wikify their case designs
Enclosure References
Software
Setting Up
PIC's must be setup with MIOS bootstrap Loader and MIOS before an application can be uploaded.
If you purchased you PIC from SmashTV or Mike's PCB Shop these will already installed.
We recommend you read the following before you continue:
Download
links
Setup Instructions
up to you
Extra
+ anything else
wikify/template/project.1228114954.txt.gz · Last modified: 2008/12/01 07:02 (external edit)
