wikify
MIDIbox Wiki Instructions
Wiki Syntax
The best way to learn the syntax and how it is used in the midibox-wiki is just to study existing pages. The syntax is easy to read and learn.
Follow this link to learn more about the syntax.
Namespaces
All wiki-pages are organized in namespaces. A namespace works exactly like a folder on your PC, but instead of a slash '/', a colon ':' is used as a separator. Links can be absolute or relative to the current namespace:
'[[:home]]' links to the page 'home' in the root namespace
'[[:mbhp:module:din]]' links to the page 'mbhp:module:din' in the root namespace
'[[mbhp:module:din]]' links to the page 'mbhp:module:din' in the root namespace
'[[.:mbhp:module:din]]' links to the page 'mbhp:module:din' in the current namespace
'[[din_dout_pin_list]]' links to the page 'din_dout_pin_list' in the current namespace
If you want to read more about DokuWiki-namespaces, follow this link.
Note that if you are on the page ':home:mbhp', you are in the namespace 'home', not 'home:mbhp'. This is a bit confusing, because there is on one hand a page called 'mbhp', on the other there is a namespace called 'mbhp' (:home:mbhp), for example 'home:mbhp:module:din'. To link from the page ':home:mbhp' to ':home:mbhp:module:din' relatively, you would use '.:mbhp:module:din'. Of course you could also use the absolute link ':home:mbhp:module:din'.
However, in most cases it will be easier and safer to just use absolute links.
Namespace Map
This is the namespace-structure of the midibox-wiki. All information concerning the midibox-project has to be somwhere in the 'home' namespace, the 'wikify' namespace is the place for information about how to edit/update the midibox-wiki.
  • home
    • about
      • faq
    • project
      • controller
        • project name if required
      • sequencer
      • synthesizer
      • misc
    • mbhp
      • module
      • pic
      • stm32
    • mios
    • mios32
    • software
    • skills
      • troubleshooting
    • community
      • bulk_order
  • wikify
    • template
Global Documentation
Homepage template, with templates for child pages, as per the above namespace map.
Documenting Projects
Documenting Modules
wikify.1229691551.txt.gz · Last modified: 2008/12/19 12:59 by stryd_one
