Both sides previous revision Previous revision | |||
wilba_mb_6582_control_surface_construction_guide [2020/12/12 18:08] m00dawg typo |
wilba_mb_6582_control_surface_construction_guide [2020/12/15 15:13] m00dawg Added link to JST cabling method |
Line 124: | Line 124: | ||
**SOLDERING RIBBON CABLE BETWEEN BASE AND CS PCBS** | **SOLDERING RIBBON CABLE BETWEEN BASE AND CS PCBS** | ||
+ | **Note** There is a potentially better method mentioned on the forums ([[http://midibox.org/forums/topic/21498-connecting-mb-6582-pcbs-with-jst-xh/|here]]) which uses JST headers on the baseboard and either right-angled JST headers on the CS or just normal right-angled SIL headers. Coupled with ready-made JST cables, this is a much simpler approach and allows the two boards to be separated easily. It is worth a look before going down the path mentioned below. | ||
This is a slightly difficult process, so I'll give as much advice as possible. | This is a slightly difficult process, so I'll give as much advice as possible. |
