wilba_mb_seq_construction_guide [2008/10/29 02:04] Wilba |
wilba_mb_seq_construction_guide [2018/04/01 21:06] phatline |
Line 19: | Line 19: | ||
Now is a good time to do a "fit test" of the PCB and panel with temporarily mounted studs. | Now is a good time to do a "fit test" of the PCB and panel with temporarily mounted studs. | ||
- | Thread spacers onto the studs which are screwed into the panel. | + | Attach 10mm spacers to the PCBs with the 3mm screws. **IMPORTANT: Align them to the centre of the mount hole!!!** You will soon be gluing them to the panel where they are placed. |
- | Attach the spacers to the PCBs with the 3mm screws. **IMPORTANT: Align them to the centre of the mount hole!!!** You will soon be gluing them to the panel where they are placed. | + | |
"Snap-in" some switches and caps. If you are paranoid like me, put them all in, except S19,S33,S26,S40, to leave room for two clamps. | "Snap-in" some switches and caps. If you are paranoid like me, put them all in, except S19,S33,S26,S40, to leave room for two clamps. | ||
Line 41: | Line 39: | ||
Now is a good time to remove the switches and solder the diodes to the PCB. Cut the diode leads short, so you can save the rest of the lead (i.e. wire lengths) for using later when joining the PCBs. | Now is a good time to remove the switches and solder the diodes to the PCB. Cut the diode leads short, so you can save the rest of the lead (i.e. wire lengths) for using later when joining the PCBs. | ||
- | Mount the spacers to the studs. | + | Mount 10mm spacers to the studs. Note: the studs where the PCBs join will have spacers permanently, but the studs on the sides will not, as that is where the panel will mount to a case. You can temporarily put spacers on the sides to ensure a solid and parallel mounting of PCBs to panel when gluing studs to panel, and later when soldering LEDs. |
Place the PCBs on the studs. Adjust the PCBs until they are aligned across the join. Use the pad holes as the best guide. Ideally the PCBs should fit together exactly. It's important to ignore the PCB outer edge and concentrate on the alignment between the two pads for the Beat LED, and that the studs are in the middle of the PCB mount holes. Once aligned, screw the nuts on the studs, flip it over and look at the switch caps. If they look aligned, then you've just rehearsed what you need to do next: glue the threaded spacers to the panel. | Place the PCBs on the studs. Adjust the PCBs until they are aligned across the join. Use the pad holes as the best guide. Ideally the PCBs should fit together exactly. It's important to ignore the PCB outer edge and concentrate on the alignment between the two pads for the Beat LED, and that the studs are in the middle of the PCB mount holes. Once aligned, screw the nuts on the studs, flip it over and look at the switch caps. If they look aligned, then you've just rehearsed what you need to do next: glue the threaded spacers to the panel. | ||
Line 64: | Line 62: | ||
Before removing the PCB, now is a good time to start soldering the wires between the two PCBs. | Before removing the PCB, now is a good time to start soldering the wires between the two PCBs. | ||
+ | ====== Joining the two PCBs ====== | ||
- | + | **This only applies to the prototype PCBs. The production PCBs (from bulk orders) are a single PCB.** | |
- | ====== Joining the two PCBs ====== | + | |
You're at this point if you had a panel with studs/standoffs built in, or just finished gluing the studs and spacers to the panel and the PCB/panel are still attached. | You're at this point if you had a panel with studs/standoffs built in, or just finished gluing the studs and spacers to the panel and the PCB/panel are still attached. | ||
Line 83: | Line 80: | ||
It needs to be stressed to the people who just like to do things differently - **YOU SHOULD NOT USE FLEXIBLE WIRE, RIBBON CABLE, INSULATED WIRE, TRANSFORMER WIRE, ENAMELLED WIRE, ETC.** | It needs to be stressed to the people who just like to do things differently - **YOU SHOULD NOT USE FLEXIBLE WIRE, RIBBON CABLE, INSULATED WIRE, TRANSFORMER WIRE, ENAMELLED WIRE, ETC.** | ||
+ | ====== WARNING! WARNING! WARNING! ====== | ||
+ | Some "16mm" rotary encoders, such as the Soundwell ones, have some extra nubs/protrusions on the encoder base. You will need to remove these nubs/protrusions for two reasons: | ||
+ | * the datawheel encoder is mounted to a hole in the PCB with a washer and nut. There is no hole in the PCB for any nub/protrusion. Therefore, to mount the encoder as close to the PCB as possible (and parallel too!), you need to remove the nub/protrusion. | ||
+ | * the step encoders are positioned very close to the step LEDs. The nub/protrusion overlaps the space where the step LED is mounted. | ||
+ | I use a Dremel (rotary tool) with a grinding disc to remove the nubs/protrusions from my encoders. If you do not have this tool, you can use wire cutters and a lot of force... or call a friend who has some tools to help you. | ||
====== Soldering Components ====== | ====== Soldering Components ====== | ||
Line 95: | Line 100: | ||
* encoders | * encoders | ||
* LEDs | * LEDs | ||
The LEDs should be soldered with the PCB and panel attached and perfectly aligned. The two parts of the PCB should also have been joined with soldered wire before soldering LEDs. | The LEDs should be soldered with the PCB and panel attached and perfectly aligned. The two parts of the PCB should also have been joined with soldered wire before soldering LEDs. | ||
- | **Rehearse/practice the following phase with a couple LEDs - inserting LEDs into the PCB, attaching the panel and flipping the panel and PCB.** | + | Rehearse/practice the following phase with a couple LEDs - inserting LEDs into the PCB, attaching the panel and flipping the panel and PCB. |
+ | **//NOTE THE ORIENTATION OF LED31/"step view" - it is opposite vs. the other LEDs! | ||
Place LEDs into the PCB. Take extra care when placing the LEDs into the PCB. In particular, the Step View LED is of a different orientation to others nearby. Attach the panel. Flip the attached PCB and panel. Lay it down with the panel slightly raised so the LEDs can fall into the holes (the switch caps and/or encoder shafts keep it raised). Use LED leads to position LED into the panel holes. Solder the longer leads of all the LEDs. Check all the LEDs are at the same height - ones that are not can be adjusted by pushing the LED while reheating the solder joint. | Place LEDs into the PCB. Take extra care when placing the LEDs into the PCB. In particular, the Step View LED is of a different orientation to others nearby. Attach the panel. Flip the attached PCB and panel. Lay it down with the panel slightly raised so the LEDs can fall into the holes (the switch caps and/or encoder shafts keep it raised). Use LED leads to position LED into the panel holes. Solder the longer leads of all the LEDs. Check all the LEDs are at the same height - ones that are not can be adjusted by pushing the LED while reheating the solder joint. | ||
Line 105: | Line 114: | ||
I used 220 Ohm resistors for SmashTV's green 3mm LEDs and 220 Ohm for SmashTV's red 5mm LED (the "Beat" LED). For the bicolor LEDs I used (and may come with your PCB), I used 470 Ohm for the green and 1K for the red. | I used 220 Ohm resistors for SmashTV's green 3mm LEDs and 220 Ohm for SmashTV's red 5mm LED (the "Beat" LED). For the bicolor LEDs I used (and may come with your PCB), I used 470 Ohm for the green and 1K for the red. | ||
|**Part**|**Suggested Value**|**Purpose** | | |**Part**|**Suggested Value**|**Purpose** | | ||
Line 121: | Line 133: | ||
* If you are not using green 3mm LEDs from SmashTV, you may need to change 220 Ohm to something else. For red 3mm LEDs from SmashTV, use 470 Ohm or 1K. For blue LEDs, consult a psychiatrist. | * If you are not using green 3mm LEDs from SmashTV, you may need to change 220 Ohm to something else. For red 3mm LEDs from SmashTV, use 470 Ohm or 1K. For blue LEDs, consult a psychiatrist. | ||
+ | ====== Parts List / Placement ====== | ||
+ | Please use the following list to stuff your PCB accordingly (yet incomplete): | ||
+ | |**Part**|**Description**| | ||
+ | |U1,U2,U3,U4,U5,U6 |74HC165| | ||
+ | |U7,U8 |74HC595| | ||
+ | |**Jumper/Connector**|**Description**|**Connecting to**| | ||
+ | |J1 | DIN/DOUT | to CORE/CORE32 Wiring 1:1 with J8/J9| | ||
+ | |J2 | DIN/DOUT | to additional control elements in the Chain| | ||
+ | |J3 | Beat LED| optional Beat LED connection (if not mounting LED to PCB)| | ||
+ | |J4 | Datawheel Encoder| to PCB using Wires | | ||
+ | |J5 | Datawheel Switch | (optional) for encoder with switch | | ||
+ | ====== Trouble Shoot ====== | ||
+ | to figure out that your problems with that pcb are softwareside (buggy firmware, or fals hw-config), you can test all Buttons and LEDs with that firmware:\\ | ||
+ | {{:phatline:SEQ-CS-TEST.zip|the Code}} | ||
