wilba_mb_seq_construction_guide [2013/09/20 21:11] smashtv Added note about LED31 |
wilba_mb_seq_construction_guide [2018/04/01 21:06] phatline |
Line 100: | Line 100: | ||
* encoders | * encoders | ||
* LEDs | * LEDs | ||
- | **//NOTE THE ORIENTATION OF LED31/"step view" - it is opposite vs. the other LEDs! | ||
Line 108: | Line 105: | ||
Rehearse/practice the following phase with a couple LEDs - inserting LEDs into the PCB, attaching the panel and flipping the panel and PCB. | Rehearse/practice the following phase with a couple LEDs - inserting LEDs into the PCB, attaching the panel and flipping the panel and PCB. | ||
+ | **//NOTE THE ORIENTATION OF LED31/"step view" - it is opposite vs. the other LEDs! | ||
Place LEDs into the PCB. Take extra care when placing the LEDs into the PCB. In particular, the Step View LED is of a different orientation to others nearby. Attach the panel. Flip the attached PCB and panel. Lay it down with the panel slightly raised so the LEDs can fall into the holes (the switch caps and/or encoder shafts keep it raised). Use LED leads to position LED into the panel holes. Solder the longer leads of all the LEDs. Check all the LEDs are at the same height - ones that are not can be adjusted by pushing the LED while reheating the solder joint. | Place LEDs into the PCB. Take extra care when placing the LEDs into the PCB. In particular, the Step View LED is of a different orientation to others nearby. Attach the panel. Flip the attached PCB and panel. Lay it down with the panel slightly raised so the LEDs can fall into the holes (the switch caps and/or encoder shafts keep it raised). Use LED leads to position LED into the panel holes. Solder the longer leads of all the LEDs. Check all the LEDs are at the same height - ones that are not can be adjusted by pushing the LED while reheating the solder joint. | ||
Line 114: | Line 114: | ||
I used 220 Ohm resistors for SmashTV's green 3mm LEDs and 220 Ohm for SmashTV's red 5mm LED (the "Beat" LED). For the bicolor LEDs I used (and may come with your PCB), I used 470 Ohm for the green and 1K for the red. | I used 220 Ohm resistors for SmashTV's green 3mm LEDs and 220 Ohm for SmashTV's red 5mm LED (the "Beat" LED). For the bicolor LEDs I used (and may come with your PCB), I used 470 Ohm for the green and 1K for the red. | ||
|**Part**|**Suggested Value**|**Purpose** | | |**Part**|**Suggested Value**|**Purpose** | | ||
Line 144: | Line 147: | ||
|J4 | Datawheel Encoder| to PCB using Wires | | |J4 | Datawheel Encoder| to PCB using Wires | | ||
|J5 | Datawheel Switch | (optional) for encoder with switch | | |J5 | Datawheel Switch | (optional) for encoder with switch | | ||
+ | ====== Trouble Shoot ====== | ||
+ | to figure out that your problems with that pcb are softwareside (buggy firmware, or fals hw-config), you can test all Buttons and LEDs with that firmware:\\ | ||
+ | {{:phatline:SEQ-CS-TEST.zip|the Code}} | ||
