Next revision Both sides next revision | |||
windows_toolchain_notepadplus [2008/05/20 06:29] 127.0.0.1 external edit |
windows_toolchain_notepadplus [2008/11/03 16:32] lylehaze |
Line 30: | Line 30: | ||
NotePad++ is really a text editor, not a full-blown IDE, but it contains all the required features for our use, and as it contains highlighting for both ASM and C apps, is perfectly suited to MIDIBox use. You can just install it using the defaults, but if you want to tweak it up good and proper, here's how. | NotePad++ is really a text editor, not a full-blown IDE, but it contains all the required features for our use, and as it contains highlighting for both ASM and C apps, is perfectly suited to MIDIBox use. You can just install it using the defaults, but if you want to tweak it up good and proper, here's how. | ||
- | * [[http://sourceforge.net/project/showfiles.php?group_id=95717&package_id=102072|Download the installer]]. You want the file named like npp.(version).Installer.exe | + | * [[http://sourceforge.net/project/showfiles.php?group_id=95717&package_id=102072|Download the installer]]. You want the file named like npp.(version).Installer.exe [note:versions above 5.03 may not work with NPPExec or Explorer] |
* Run the installer. | * Run the installer. | ||
* Select your language, Click 'Next, 'I Agree', and 'Next'. | * Select your language, Click 'Next, 'I Agree', and 'Next'. |
