windows_toolchain_quickstart [2013/02/16 19:15] root fixed link to gputils |
windows_toolchain_quickstart [2013/04/22 18:10] root [MSYS] |
Line 14: | Line 14: | ||
* Install using defaults | * Install using defaults | ||
==== MSYS ==== | ==== MSYS ==== | ||
- | * [[http://sourceforge.net/projects/mingw/files/MSYS/BaseSystem/msys-core/msys-1.0.11/MSYS-1.0.11.exe/download|Download MSYS 1.0.11 Installer]] | + | * [[ |
+ | * http://downloads.sourceforge.net/mingw/MSYS-1.0.11.exe|Download MSYS 1.0.11 Installer]] | ||
* Install using the defaults. | * Install using the defaults. | ||
* When the install is almost complete, you will see a DOS console window open, and you will be prompted: "Do you wish to continue with the post install? [yn ]". Type 'n' (without the quotes) and hit Enter. | * When the install is almost complete, you will see a DOS console window open, and you will be prompted: "Do you wish to continue with the post install? [yn ]". Type 'n' (without the quotes) and hit Enter. |
