dipboardf4_modules
dipBoardF4 Modules
Basic connection Modules for dipBoardF4 and dipCoreF4.
Features
  • Dual OTG USB, one Dual role(mini-AB, B) and second is Host only(A).
  • DC Input 9-12V with 5V regulator, switch and led.
  • In device Mode, VBUS is switched off when DC Input is enough to supply the 5V regulator.
  • Power switch also acts on USB powering.
  • micro-SD Card socket with push-push.
  • Reset and User buttons, 2 leds for user purpose.
  • Dual MCAN bus RJ11 connectors with 120Ω termination switch.
Dimension
PCB
2 layers PCB design.
Fits 2 layer mostly common design rules.
  • min. drill 10mil
  • min. width 6mil
BOMs
USB Module
version 1. Mouser BOM:toDo
Qty Value Package Parts MouserReicheltConradOtherNotes
Resistors
4 22R 5% 0603 R1, R2, R3, R4
1 680R 5% 0603 R5 Depends on Led
PTC fuses, resettable thermistors
1 1206L150THWR1206F1576-1206L150THWR
Capacitors
1 100n 0603C2
1 4,7u SMC_AC1
ESD Suppressors / TVS Diodes
7 CG0603MLC-05E0603Z1, Z2, Z3, Z4, Z5, Z6, Z7652-CG0603MLC-05E
Ferrite Bead
1 BLM210805L1 512-1N4148WS
LEDs
1 –0805 or THT LED_OC 2x5mm rectangular THT
Transistor
1 FDN304P SSOT-3 Q1 512-FDN304P P-Channel MOSFET
IC
1 STMPS2161STRSOT23-5LIC1 511-STMPS2161STR Power Switch IC
Connectors
1 mini-USB THT MINI-USB 571-1734510-1
1 USB-B THT USB-B 538-67068-8000
1 USB-A THT MINI-A 538-48204-0001
1 micro-match 2×4 FemaleJ2A 571-7-215079-8 or 571-2178710-8 (value line)
1 micro-match 2×6 FemaleJ1A 571-8-215079-2 or 571-1-2178710-2 (value line)
Others
2 Screw terminal – – 534-7790
External Power Module
Resistors
1 680R 5% 0603 R10 Depends on Led
2 10K 5% 0603 R6, R7
1 22K 5% 0603 R8
1 33K 5% 0603 R7
Capacitors
2 100n 0603C5, C6
2 47u THTC3, C4 6mm diam. 2.5mm lead space
Diode
1 SB240 DO15 D1 625-SB240-E3
LEDs
1 –0805 or THT LED_PWR 2x5mm rectangular THT
IC
1 LD1086DT50TRDPACKIC2 511-LD1086DT50TR
1 LM321MFSOT23-5IC3 926-LM321MF/NOPB Low Power Single Op Amp
Switch
1 E201J1AV2 – PWR_SW 611-E201-004 DPDT power switch(same as Sammich…)
Connectors
1 micro-match 2×4 FemaleJ2B 571-7-215079-8 or 571-2178710-8 (value line)
1 DC in Socket Opt*1 FemaleDC_IN 651-1729128 Jack on board
1 DC in Socket Opt*2 FemaleDC_IN 651-1729128 + 502-712A Screw terminal on board(Board/Switch on front) + Jack on backpanel
Others
SD Card Module
Resistors
2 680R 5% 0603 R15, R16 Depends on Led
2 100K 5% 0603 R13, R14
Capacitors
2 100n 0603C11, C12
LEDs
2 –0805 or THT LED1, LED2 2x5mm rectangular THT
Switches
2 B3F-31xx – USER, RESET 653-B3F-3122
Connectors
1 DM3AT-SF-PEJM5 Socket micro-SD 571-8-215079-4 with push-push
1 2×7 Female J16E 571-8-215079-4 or 571-1-2178710-4 (value line)
Others
MCAN Module
Resistors
1 100R 5% 0603 R12
1 1K 5% 0603 R11
1 1206L150THWR1206F2576-1206L150THWR
Capacitors
2 100n 0603C8, C10
2 1u 3225C7, C9
1 PESD1CAN SOT23Z8 771-PESD1CAN-T/R
Diodes
1 LSM115J DO214BA D2 494-LSM115JE3/TR13
Ferrite Bead
1 BLM210805L2 512-1N4148WS
Relay
1 TLP175A SOP4 Q1 757-TLP175A(TPLE Photorelay MOSFET
IC
1 TCAN1042GVSOIC8IC4 595-TCAN1042GVDRQ1 CAN tranceiver
Switch
1 1101M2S3AV2BE2 – TERM 611-1101M2S3AV2BE2
Connectors
1 RJE0166202 dual RJ11 6p6c MCAN 523-RJE01-662-02
1 micro-match2x3 Female J18 571-215079-6 or 571-2178710-6 (value line)
Others
dipboardf4_modules.1538766043.txt.gz · Last modified: 2018/10/05 19:00 by antichambre
