midiboxkb_-_using_a_c64_keyboard_as_input
MidiBoxKB
Since Thorsten released a 8*8 scan matrix driver,
it's easily possible to use a C64 Keyboard with MIOS.
http://www.midibox.org/forum/index.php?topic=6505.msg40727#msg40727
The C example can be downloaded here :
First, i did this pcb (on a breadboard) :
The program
Use that sample program to test your keyboard connection :
This small app display the key number, the corresponding Character, the midi note number associated to that key, and play a note on channel 1. The keyboard mapping can be found in the “variables.h” file. More than a test, it's a good base for your own programs.
A bigger and more interesting program (a funky sequencer) is still on developpement… stay tuned !
It can look like this
Please write me if you have questions.
Get various files and details related at http://jambonbill.free.fr or http://jambonbill.free.fr/?rep=./midibox-kb
— bill 2006/05/02 05:06
More photos
Bugs
Atm, some key combination lead to errors :
The C64 keyboard pcb do not have signal leds. So, when you try to play some chords (no worry, only a few of them) the scan matrix do not read the keyboard correctly. I guess that problem exist on the real C64, but is not a problem because there's no need to press 4 keys at the same time, in a normal way of use. Most or all 3 notes chords can be played with no problem.
I dont know why the formating of this page is all fucked up :s
midiboxkb_-_using_a_c64_keyboard_as_input.txt · Last modified: 2011/11/30 02:31 by smashtv
