daw-encoder-display
Differences
Both sides previous revisionPrevious revisionNext revision | Previous revision | ||
daw-encoder-display [2022/05/28 16:47] – [Building and BOM] phatline | daw-encoder-display [2023/03/02 04:15] (current) – phatline | ||
Line 7: | Line 7: | ||
**It is one part to build a DAW-controller, | **It is one part to build a DAW-controller, | ||
Here are the gerberfiles for production - i made it with[[https:// | Here are the gerberfiles for production - i made it with[[https:// | ||
- | + | testet | |
- | They are not testet | + | {{youtube> |
====== Shematic ====== | ====== Shematic ====== | ||
Line 17: | Line 19: | ||
====== Building and BOM====== | ====== Building and BOM====== | ||
- | The Values are printet on the PCB. | + | The Values are printet on the PCB. |
**Following Quantity is for 1 PCB, Mouser:**\\ | **Following Quantity is for 1 PCB, Mouser:**\\ | ||
Line 32: | Line 35: | ||
660-RK73H2ATTD1002F|27\\ | 660-RK73H2ATTD1002F|27\\ | ||
660-RK73H2ATTD1002F|3\\ | 660-RK73H2ATTD1002F|3\\ | ||
+ | 771-74HC165D-T|3\\ | ||
You may change the how many times you want to order this project\\ | You may change the how many times you want to order this project\\ | ||
Line 42: | Line 46: | ||
====== To Do ====== | ====== To Do ====== | ||
- | Waiting for the PCBs, Test them, make a Frontpanel.\\ | + | make a Frontpanel.\\ |
====== Community users working on it ====== | ====== Community users working on it ====== | ||
Line 48: | Line 52: | ||
Just let a Private message on the forum to user already involved.\\ | Just let a Private message on the forum to user already involved.\\ | ||
+ | or join the forum: [[http:// |
daw-encoder-display.txt · Last modified: 2023/03/02 04:15 by phatline
